Old 06-08-2016, 10:23 PM   #1
dazza
dazza's Avatar
Lubricating the dust & timing chain covers
ok, so I have about 200 miles on the complete rebuild and running great. I just noticed a few drops of oil on the dust cover as well as a few at the pan drain plug. Looking at the front of the dust cover it has been hit by a few flying drops but not many. Pulled the cover to find a bit of oil along the the top REAR ridge and and of course seeing where it has flowed down and out the hole. Looking up at the clutch there is splatter on the ceiling of the bell-housing as well as grease and (I think)oil at the throwout bearing and clutch fork.
you think from external seeping in or possible rear main seal??
Also noticed a few drips on the other end... on the bottom of my timing chain cover (last picture).
Name:  File Jun 08, 6 51 41 PM.jpg
Name:  File Jun 08, 6 50 52 PM.jpg
Name:  File Jun 08, 6 57 09 PMsm.jpg
Name:  File Jun 08, 7 19 00 PM.jpg
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 06-09-2016, 10:34 AM   #2
midniteblues
midniteblues's Avatar
Re: Lubricating the dust & timing chain covers
On timing covers I always install the damper then tighten the cover bolts. it helps too center the seal on the damper.
They can also develope a groove a speedy sleeve will help with this. Lubing the seal or damper when installing will keep it from burning up before it gets engine oil.
If there is oil between the flywheel and block suspect the rear main or oil pan seals.
If the oil is on the throw out bearing side it could be coming from the input shaft of the trans.
I've seen throw out bearings sling grease in the bell. That never concerned me unless it was noisey. Lookin back at you pic the grease on the bearing should be there it's too lube the fork and bearing contact area. Also should be some on the sleeve of the bearing retainer.
Just trying too help here.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-09-2016, 10:59 AM   #3
maybe putting that dye in the oil would help you figure it out. I could guess, but with oil showing front and back the only single problem I can think of is pan gasket didn't seat well. That's the only thing both areas have in common. Could be separate issues
Old 06-09-2016, 11:06 AM   #4
midniteblues
That's a good idea there tim.
I guess it wouldn't hurt too check the snuggness of the pan bolts also after the 200mi. Of Heat cycles.
Old 06-09-2016, 01:06 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If a Small Block Chevy isn't leaking oil... it's OUT!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-09-2016, 03:51 PM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Gary
Yes, re-snug them pan bolts, header & intake bolts as well, especially after a rebuild...Gary's disgustingly right though, so keep a rag handy!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-10-2016, 12:00 AM   #7
ElKotze
ElKotze's Avatar
What oil pan gasket did you use? The 4-piece is crap, you never get them to seal right. I recommend the felpro 1-piece gasket, it's a blue rubber piece. Works great.
ElKotze is offline   Reply With Quote
Old 06-10-2016, 02:08 AM   #8
dazza
dazza's Avatar
I was thinking input shaft as well and because it's been a few years (long project) since I installed the clutch I couldn't remember if I had or was supposed to lube the fork area or not.
and it's appreciated! Thanks
pan gasket
those two words unlocked that folder in some directory somewhere in my brain, the one I lost only a few short days ago, labelled "To Do Because You Noticed It Needs To Be Done" ... but what was it?
well thanks to midniteblues addition of the word "snuggness" I finally remembered being under the truck doing something and found a loose pan bolt... one of those, "I'll get right on that as soon as I finish... blah blah blah".
Hopefully the solution, as most needed it! Going on a snugging hunt tomorrow.
Gary
If I remember correctly, a tiny leak was why I pulled my truck into a friends garage some seven or so years back, and just drove it out a few weeks ago!
yep, that's what's in there!
Thanks for all your input and memory jolting!!
