Old 06-09-2016, 11:47 AM   #1
Nodnarb76
Nodnarb76's Avatar
6.0 Swap w/new Enytropy Radiator/Fans running hot when not moving.
Still fixing all the little problems after doing my 6.0/4L80 Swap into my 87 Suburban. Along with the motor installed an Enytropy radiator/fan kit.
Fans come on low speed then high speed like they are supposed to.
When I'm driving and have airflow through the radiator, everything is fine, once I come up to a light or stop, temp goes up about 20-30 degrees, even if the fan is on high speed, then goes back down when I start moving. When I installed the motor I replaced the water pump and thermostat with new AC Declo parts.
Any ideas?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 06-09-2016, 11:53 AM   #2
solidaxel
solidaxel's Avatar
Re: 6.0 Swap w/new Enytropy Radiator/Fans running hot when not moving.
Sounds like air trapped in your system do not for get to turn the heater on to circulate the water through the heater core
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-09-2016, 12:30 PM   #3
Nodnarb76
Nodnarb76's Avatar
That is what I was thinking also, going to pull a vacuum on it this afternoon at work and see if it helps.
Thanks for confirming what I was thinking.
Old 06-09-2016, 12:33 PM   #4
solidaxel
solidaxel's Avatar
Did you fill the engine from the top radiator hose dis connected from the rad?
LS 3 4L70E
Old 06-09-2016, 01:21 PM   #5
Nodnarb76
Nodnarb76's Avatar
I did, I filled through the upper radiator hose until I had coolant coming out of the steam hose, re-connected everything. Because my filler neck is at an angle I even jacked up the pass side of the truck to try and get the filler neck level so it would hold more coolant when I filled the radiator.
Old 06-09-2016, 01:48 PM   #6
TooTall
are you sure that the fans are blowing in the right direction?
1984 K10, 8" lift on 35s
2011 Yukon XL | Bone stock
2013 Audi Q5
Old 06-09-2016, 01:52 PM   #7
Nodnarb76
Nodnarb76's Avatar
Pretty sure they are, they would only plug up one way, when the fans are on high speed, I can put a rag in front of the grille and it will pull it toward the grille.
Old 06-10-2016, 09:01 AM   #8
Nodnarb76
Nodnarb76's Avatar
update: when driving to work today started getting hot when driving on interstate too. then when came to a stop still getting hot. Fans are coming on, no leaks anywhere, when I pulled over overflow tank was bubbling.
Is it possible a new AC delco thermostat is sticking?
Old 06-10-2016, 03:22 PM   #9
LS short box
If you think there is still trapped air in the system try loosening the temp sensor till you get some coolant to run out. Careful of the hot coolant.
LS short box is offline   Reply With Quote
Old 06-10-2016, 05:58 PM   #10
TooTall
I would crack the steam hose after it's been up to temp
it almost sounds like you have a leak in the system and it's not pressurizing up, or your coolant mixture is off
2013 Audi Q5
Old 06-10-2016, 09:55 PM   #11
zach_carver
zach_carver's Avatar
How hot is it getting? My LS2 runs 210ish on the highway on a good hot day. Sitting still in traffic 212-215ish.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 06-19-2016, 08:52 PM   #12
tony2tall
Just used that spill free funnel thing for burping my system today. Works great. Might be worth a try.
tony2tall is offline   Reply With Quote
Old 06-21-2016, 10:05 AM   #13
1moretoy
Just replaced my water pump and installed a new 160* thermostat from summit. Engine was doing the same thing you are describing at idle though. Fans working and water everywhere, no air in the system. Ended up the thermostat was stuck closed replaced with a factory one from parts store and works perfect now.
1moretoy is offline   Reply With Quote
Old 06-21-2016, 10:32 AM   #14
Nodnarb76
Nodnarb76's Avatar
That is what I ended up doing too. Swapped for a new thermostat and I have no more problems either.
