Old 06-10-2016, 02:00 PM   #1
DANTIP
DANTIP's Avatar
Front tires skid during low speed turns
I test-drove a nice '72 1/2-ton 2WD and it drove straight as an arrow but seemed to bind hard in a low-speed turn (like turning into a parking spot). I wonder if it could have the wrong pitman arm or steering gear??
P.S. It wasn't turning sharper than it should have when it began binding and skidding.
DANTIP is offline   Reply With Quote
Old 06-10-2016, 02:06 PM   #2
n33k0
Re: Front tires skid during low speed turns
My truck does this, so I'm curious what the cause is as well. I know the front shocks are worn out, so I thought that was what was causing the problem, but I'm not sure.
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 06-10-2016, 02:31 PM   #3
cleszkie
cleszkie's Avatar
Sound like too much toe-in. Truck will drive straight, but outer tire will under steer in turns, causing it to scrub.
cleszkie is offline   Reply With Quote
Old 06-10-2016, 07:36 PM   #4
mike16
check front end alignment. Or air pressure in tires
mike16 is offline   Reply With Quote
Old 06-10-2016, 08:46 PM   #5
poway
when I rebuilt my front end on my 68 truck I encountered the same problem. I had the drag link on backwards. Drove straight just fine but the front tires scrubbed in turns. it was especially noticeable when I made sharp turns at low speeds. Putting the drag link on correctly remedied the problem. Just a thought.
poway is offline   Reply With Quote
Old 06-12-2016, 07:22 AM   #6
DANTIP
DANTIP's Avatar
That was it! Your suggestion along with these pics confirmed the centerlink is on backward! Good catch!!
http://67-72chevytrucks.com/vboard/s...d.php?t=400205
Dan
Old 06-12-2016, 12:01 PM   #7
davepl
davepl's Avatar
I was going to say "Ackerman angles" but that's quite a catch to pick it up and diagnose the centerlink from the symptoms!
Just goes to show what collective knowledge is worth when people are paying attention. Thanks poway!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-12-2016, 07:20 PM   #8
tdangle
tdangle's Avatar
I would like to understand this. I will be rebuilding the front end this summer and want to make sure I put everything back on correctly. By drag link do you mean the center link (bar) that connects the two tie rod ends and the steering link and the idler link? How can this be put on backwards? Pictures would be great.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-12-2016, 08:38 PM   #9
trkfrk
trkfrk's Avatar
I made the same mistake when I put my front end together. It's an easy mistake to make. I posted a picture of my new a-arms on my build and someone noticed it.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 06-12-2016, 08:53 PM   #10
trkfrk
trkfrk's Avatar
Yes, it can go on either way without rubbing anything. See pic. The inner tie rod end nut should be facing out.
Mark
Old 06-12-2016, 11:55 PM   #11
tdangle
tdangle's Avatar
OK, Got it now! Thanks for the clarification and pic
Terry
Old 06-13-2016, 12:34 AM   #12
midniteblues
midniteblues's Avatar
I'm not real familiar with tubular control arms.
But upper stock arms the ball joint sits on top of the arm. That's the first I've ever see them on the bottom of the arm.
It's just too easy too bolt that center link on wrong. Been there done that.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
