Stock Driveshaft capacity
Just curious... anyone want to comment on max hp/tq that a stock lwb 2pc driveshaft will take before it breaks?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
prob over 300. if your driving normally. now if ur
70 longbed 496/th400/Ford 9" |
THE QUICKER FIXERUPER
Ive got over 400hp and drive
its all about the +6 inches
I have seen a daily driver that ran 12's every weekend. He drove it like that for over a decade before it got totaled.
Other than a couple U-joints and C-bearings wearing out, he never had an issue witht eh driveshaft. |
I am just trying to prioirtize my funds for my truck was trying to guess when to count replacing it and having a bigger one built. I don't have any issues now but it doesn't hook up either.
Just rmember: U-joints are cheap. Virtually everything on either end of them is expensive.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
yeah last time i priced having a custom one built it was $500.
we have 900+hp with no problems
Okay........what the heck are you runnin that has 900hp????
it's a 542ci Siamese cylinder, scat steel stroker crank, aluminum bowtie heads w/ a 1250cfm TPI. we use the truck mainly for advertising but when we built it we had Venolia cut a custom set of forged pistons @ 9.75 to 1 so we could burn premium pump fuel (and it uses alot of it about 2 mpg) without pinging so it could be driven to the shows and such.
[IMG]http://www.****************.com/boardpics/eng1.jpg[/IMG] |
What cam/heads?
How did you guys do it with no NOS/blower or turbo? and low compression?
give me a few minutes and I will give you a whole write up on it (lots of typing)
#13 |
Why don't you pm me? Then we won't take up the whole post.
#14 |
motor
Engine:
542 inch Prostock block from chevy programable 1250 cfm TPI w/ 52 psi Injectors 1/4" stroker crank from Calles 9.1-1 comp 4.5000" custom made piston from venolia (I was mistaken on that one earlier) Aluminum D port heads (2.130 Intake 1.88 exhaust) w/ manley SS valves Comp roller cam (.556 lift 280 duration) comp roller rockers Fluid dampner (It's been together for a few years so I am sure I forgot something) Last edited by rickspickuppart; 10-01-2003 at 05:58 PM. |
#15 |
sorry this is way off topic of the original thread, I didn't see your PM idea till after I hit "submit reply"
#16 |
thanks.
#17 |
He isn't the only one that was wondering about 900 horsses.
Good info. Have you had it down the 1320 yet? If it hooks up it should be pretty fun, but I think you'd be kicked off the track for lack of safety equipment after the first run huh? |
#18 |
it would get kicked and the tranny wouldn't stand it if it ever "hooked" up, just wait till truck 3 is done (it might take a couple years) w/ a merlin 705 and the drivetrain to back it up and it will be street legal (1400hp plus). We are starting to gather the pieces for the body now.
Shawn |
#19 |
Shawn,
Well the next time I am down there visiting my in laws I will have to come and check you guys out!!!!!!
#20 |
definetly do (most of the time people treat it like a car show w/ the customer jobs we got going on)
#21 |
maybe when you are here we will go for a ride (it is always fun at 90mph in high gear at 1/3 throttle to start burning the tires)
#22 | |
