![]() Join Date: Mar 2014
1971/72 front disk brake exploded view
After hours of searching on here and the web I can't seem to find an exploded view of the 71-72 front disk brake assembly. My project is utilizing a factory 71-72 stock height spindle and therefore I wanted to keep the brake components from the same year range. However, I can't find a factory exploded view or parts list that has all the nuts and bolts included. The following is what I can come up with from memory:
-dust shield (no idea what the bolt size and pitch is to attach them to the spindle) -rotor -caliper w/pads -caliper bolts -inner seal -inner bearing -outer bearing -thrust washer -castle nut -cotter pin for castle nut -dust cap I wanted to verify what I came up with from memory to an exploded view. Anything I left out? I know there are kits out there where you can but all the components but I wanted to see if I could piece it together for cheaper, plus I already have the spindles. Thanks Last edited by 88k5jimmy; 06-10-2016 at 10:33 PM. |
Re: 1971/72 front disk brake exploded view
I believe the dust shield bolt size is 5/16" - 18 X 7/8"
Jake ____________________________________________ Straight roads are for fast cars, turns are for fast drivers. |
![]() Join Date: Oct 2009
Have you checked out an Assembly Manual? Don’t have one handy or I’d look it up. I would think the Service Manual would also have a good image, maybe not exploded though.
67-72 parts collector,…
![]() Join Date: Nov 2002
Does this help?
http://67-72chevytrucks.com/vboard/s....php?p=5781194
