06-10-2016, 11:57 PM | #1 |
Need info on where to get rear door window rubber
Recently picked up a 59 panel. Unfortunately someone installed a set of aluminum framed side windows which look horrible. I would like to eliminate the aluminum frame & just install flat glass. To look the best it can I would like to use the same rubber seal used on the barn door windows.
Does anyone know of a source that I could get this rubber seal? Any info is appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
06-11-2016, 05:48 PM | #2 |
Re: Need info on where to get rear door window rubber
You can buy universal window rubber by the foot from glass shops or online.
I'm assuming that you are trying to replace some side camper windows someone stuck in the sides of the panel. The rubber locking gasket on this page is pretty much like a lot of oem rubber that has the lock strip https://www.trimlok.com/ https://www.amazon.com/Glass-seal-wi...=1&*entries*=0
06-11-2016, 10:53 PM | #3 |
Thanks very much, appreciate the info
