Old 06-11-2016, 01:54 AM   #1
KilroyWasHere
Exhaust system for 66 fleetside
So my exhaust system currently ends just behind the cab. I love how loud the thing is, but sometimes it gets to be a real pain. In order to extend it I know the pipes need to go around the trailing arms. Is there a specific setup out there I can get, or am I better off having a shop bend some pipes for me?
KilroyWasHere is offline   Reply With Quote
Old 06-11-2016, 07:38 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Exhaust system for 66 fleetside
Get a couple of estimates from exhaust shops and see where you are. They make that work look easy. Its probably the better way to go.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-11-2016, 12:08 PM   #3
jayoldschool
Moderator
Just have a look at the pipes on rockauto. Buy the over the axle pipe locally, add whatever straight piece and a muffler to connect. Cheap and easy.
jayoldschool is offline   Reply With Quote
Old 06-11-2016, 05:30 PM   #4
LVPhotos
LVPhotos's Avatar
Top one is my soon to be installed, the other are forum members
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-12-2016, 12:55 AM   #5
Captainfab
60-66 Nut
Here is a complete exhaust system, but you might have to modify it slightly for an exact fit to your truck.
https://www.summitracing.com/parts/w...del/c10-pickup
Old 06-12-2016, 07:55 AM   #6
gmcdeadhead
gmcdeadhead's Avatar
i bought this system that captain fab quoted , and installed it on my 66 c20 , 350 , headers. you might as well throw away the clamps they supply and get the heavy duty ones at a local auto parts store , unless your gonna weld the whole system up , those clamps are garbage , other than that i had to heat up the tail pipe on the right side and just bend it a little bit for some more clearance . the mufflers sound OK , they don't drown you out while driving. there actually not bad . hope this helps.
gmcdeadhead is offline   Reply With Quote
Old 06-12-2016, 10:09 PM   #7
KilroyWasHere
[QUOTE=gmcdeadhead;7622516]i bought this system that captain fab quoted , and installed it on my 66 c20 , 350 , headers. you might as well throw away the clamps they supply and get the heavy duty ones at a local auto parts store , unless your gonna weld the whole system up , those clamps are garbage , other than that i had to heat up the tail pipe on the right side and just bend it a little bit for some more clearance . the mufflers sound OK , they don't drown you out while driving. there actually not bad . hope this helps.[/QUOTE
Thanks for the advice, my truck is almost exactly as your setup pre-exhaust replacement. Thank you all for the help, I'll probably work on putting that in after tires
