Old 06-11-2016, 09:34 AM   #1
Fiftee3
Fiftee3's Avatar
Ball joint spacer/washer question
Hello all,
Buttoning up my JW Rod Garage IFS. Final install. On the upper and lower control arms supplied, came a steel washer/spacer. Lower is thicker than upper. Not sure if these go onto ball joint first, or after as a spacer under the nut.
This is probably a dumb question, but im not sure. Thanks if anyone can shed light.
"All the best, Phil"
My 53 IFS air bagged Upgrade Here
One of my threads for this build...
http://67-72chevytrucks.com/vboard/s...12#post7662512
Fiftee3 is offline   Reply With Quote
Old 06-11-2016, 11:39 AM   #2
Wrenchbender Ret
Re: Ball joint spacer/washer question
They are washers that go next to the nut.
Wrenchbender Ret is offline   Reply With Quote
Old 06-11-2016, 04:57 PM   #3
Fiftee3
Fiftee3's Avatar
Naturally! I put them on the ball joint studs and then tried to put spindle on.
Boy, am I an idiot!
Thanks...
