Old 06-11-2016, 01:01 PM   #1
Blu64c10
Crooked bed
My truck bed never sat level, one corner always seemed to be lower then the rest. Upon removing my bed I noticed what seemed to be the cause of this. Of the two most rear bolts holding the bed on, one had some type of spacer and the other side did not. It seems to me that the side with the spacer is the correct side. Does anyone know if these are reproduced? What they are called? And where I can get a set?
Side without spacer
Side with spacer
Blu64c10 is offline   Reply With Quote
Old 06-11-2016, 05:26 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Crooked bed
Here's lmc truck. Available at others as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-11-2016, 09:25 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Crooked bed
just the mount isn't available but LVPhotos shows the part as a rear cross sill, fleetside. I would call Mar-K, they make the best. I have purchased a few from them, among other parts.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-12-2016, 10:02 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Crooked bed
It's sold as a unit via LMC, cross member with the mounts attached. Thats where I bought mine. Of course I wasnt looking for just the mount...
