Old 10-01-2003, 12:25 AM   #1
Injected68LS1
Injected68LS1's Avatar
What 5 lug axles will fit my 68 SWB?
Does anybody know if I can swap in 5 lug axles out of later trucks? Mine is a 1/2 ton, short bed, 2WD with coil springs.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 10-01-2003, 12:39 AM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
The axles on '67-70 trucks are a differnt lenght than on later trucks....it would proably be easiest to swap in a complete rear axle out of a '71-'72 truck.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-01-2003, 12:53 AM   #3
Injected68LS1
that sux. I guess I'll have to buy some conversion axles.
Old 10-01-2003, 08:18 AM   #4
kaycee
kaycee's Avatar
I just did
this swap I made some spacer plates to go between the backing plate and rear end housing they were 3/4 " thick for each side.They line out perfect now and a hell of alot cheaper than new axles I was told the drums off a 73 heavy half ton would work as they were wider never tried it though
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 10-02-2003, 12:16 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
3/4 each side? I thought it was 3/4 TOTAL, putting a 3/8 inch spacer on each side?
Old 10-02-2003, 04:21 PM   #6
kaycee
kaycee's Avatar
ttt Nope I got 3/4" on each side
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 10-02-2003, 05:34 PM   #7
rickspickuppart
I use factory 6 lug axles that we send to a machine shop and have them redrilled (and one hole filled) as a 5 lug pattern, it is cheaper and alot easier since there are a lot of six lug axles around.
rickspickuppart is offline   Reply With Quote
