Old 06-12-2016, 05:00 PM   #1
Mike c 10
Mike c 10's Avatar
Need help with turnsignal switch c 10 1966
Hello !!
I ve a 1966 chevy c 10 The original Switch on the steering wheel for the turnsignals and horn was missing. I couldn t get one over here..so I bought a universal turnsignal Switch with emergancy Switch. van someone tell me how I can conect this one to the original conection that is under the dash..... I ve make some pics and I ve numbered the original conection under the dash... 1 and 5 are going to the breakswitch and 4 is the horn. I ve 7 cables on the new one bu where to go...thank you for your help Many thanks Mike
Mike c 10 is offline   Reply With Quote
Old 06-12-2016, 05:44 PM   #2
Brandons63
Re: Need help with turnsignal switch c 10 1966
Originally Posted by Mike c 10 View Post
Hello !!
I ordered my new one from summit racing last week!
Brandons63 is offline   Reply With Quote
Old 06-12-2016, 11:50 PM   #3
sampsmit000
sampsmit000's Avatar
get this! worked great in mine. http://www.brotherstrucks.com/64-66-...tinfo/SWTS066/
1964 Chevy Factory K10 Short Bed
Mitchell Sampson
sampsmit000 is offline   Reply With Quote
Old 06-13-2016, 01:04 AM   #4
jtrichard
Purple is power from flasher ..... Black is horn .....Dark Blue is right front....White is power from brake switch.... Light Blue is left front...... Dark Green is right rear.....Yellow is left rear... ONLY ONE COMES FROM/GOES to brake switch...... Blue on your new switch does NOT get used on your truck and you need a remote horn button
jtrichard is offline   Reply With Quote
Old 06-13-2016, 04:36 AM   #5
Mike c 10
Mike c 10's Avatar
Thanks !!! will try this later...
Old 06-13-2016, 01:58 PM   #6
Mike c 10
Mike c 10's Avatar
Hey thanks for th Infos !!!! Flasher is working now !!!
Old 06-13-2016, 02:09 PM   #7
jtrichard
Glad it worked for you .... I was hoping my explanation was understandable
Old 06-19-2016, 02:47 PM   #8
Mike c 10
Mike c 10's Avatar
Yes it works ... Thanks !! Today I ve checked all the dash lights .. all are working now... I find a Cable but couldnt figure out where to go ... is in the same Direktion like the Batt , Oil, Fuel, Temp.... the Color is dark greeen and thr other is a lighter green thesy come togeter in one conektor.... what could that be???
Old 06-19-2016, 02:50 PM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
reverse lights
3 speed & powerglide switch is located halfway down the steering column.
Old 07-03-2016, 04:17 PM   #10
Mike c 10
Mike c 10's Avatar
reverse lights
Hello aerotruck..thanks for the Info... I ve surched down the steering colum but there is nothing to conneckt...maybe I can make a extra Switch for the reverse lights ..do you know how...Thanks...
Old 07-03-2016, 10:40 PM   #11
jtrichard
There should be a small hole for this switch http://www.ebay.com/sch/i.html?_from...745921&_sop=15
