Old 06-12-2016, 10:23 PM   #1
reed62
reed62's Avatar
Torsion bar removal
Okay, so I removed the cross member and the front lower control arms. So how does one remove the actual 4 ft long bars that connect to the cross member and the lower control arm? Are they pressed on?
reed62 is offline   Reply With Quote
Old 06-12-2016, 11:44 PM   #2
Brad54
Brad54's Avatar
Re: Torsion bar removal
A large hammer, and a large drift pin of some type.
Some heat on the sleeve of the lower a-arm doesn't hurt either.
And while you are wailing away on the bar to drive it out... when you miss (and you will) and smash your hand (and you will), try not to put on too much of a show for the neighborhood kids. Not... um... that I did anything like that... I HEAR that's possible...
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-13-2016, 11:16 AM   #3
LVPhotos
LVPhotos's Avatar
No heat. Use penitrating oil, WD 40 not the blue can but the new penitrating silver and black can. PB Blaster, Kroil or the like. Use a bar or something something solid to knock the bars out with it 2 pound Sledge worked. It's the dirt and rust holding in. Heat will mess with spring so use sparingly. Page 8 on build thread.
http://67-72chevytrucks.com/vboard/s...=560081&page=8
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-13-2016, 11:05 PM   #4
Brad54
Brad54's Avatar
I should clarify: A little heat on the part of the a-arm that the end of the torsion bar sits in, will expand the metal a little, giving some clearance.
Just warm it up, don't make it cherry red.
And even if you DID make the A-arm cherry red, that won't affect the spring inside the arm (though I wouldn't want to use that control arm after that)
-Brad
Old 07-13-2016, 09:24 PM   #5
62CiscoKid
Hello Reed,
If you still have the bars off.. Would you mind measuring the exact length in inches? 45" or 48" or other?
Thanks,
Joe
62CiscoKid is offline   Reply With Quote
Old 07-18-2016, 10:31 PM   #6
reed62
reed62's Avatar
Originally Posted by 62CiscoKid View Post
Hello Reed,
Thanks,
Joe
Sorry Joe, I hauled those off to the scrap dealer several weeks ago. I ended up scoring a 70 C-10 cross member and control arm setup.
Old 07-19-2016, 03:27 PM   #7
62CiscoKid
Cool Re: Torsion bar removal
Thanks Reed.. All good. I'm collecting the information for a side project on the truck.
Joe
Old 07-19-2016, 04:02 PM   #8
62stepside longbox
62stepside longbox's Avatar
Joe
If you would like I can measure them when I have them out, should be sometime near the beginning of August
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 07-19-2016, 07:21 PM   #9
62CiscoKid
62 Stepside,
That's sounds good and will definitely be appreciated.
-Joe
