Old 06-13-2016, 12:00 AM   #1
67chevy1series
67chevy1series's Avatar
4l60e kicks into drive hard
So I've been trying to figure out why my 2002 4l60e kicks into drive hard. I've seen people having other problems in series with the Trans harshly kicking into drive but I don't have any other problems, shifting from one gear to another is nice and in a timely manner and I have reverse, which doesn't kick into gear harshly also my down shifting is normal, and my torque converter locks up and unlocks normal as well. I'm using TCI's EZ-TCU with TCI's remote mount TPS. My TCU isn't throwing any codes either. Anybody have any ideas?
67chevy1series is offline   Reply With Quote
Old 06-13-2016, 12:41 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l60e kicks into drive hard
Are you running an NSS?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-13-2016, 01:33 AM   #3
67chevy1series
Are you talking about the neutral safety switch on the gear selector? If so I am not, the harness for the TCU doesn't have any wiring pigtails that go to the switch on the gear selector
Old 06-13-2016, 01:40 AM   #4
67chevy1series
I would also like to add that I am running the stock 72 truck til it column neutral safety/ BU light switch
Old 06-13-2016, 07:45 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
is your idle rpm high?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-14-2016, 01:58 AM   #6
67chevy1series
My idle in Park/Neutral is 700 and in Drive the idle drops to 500
Old 06-14-2016, 02:09 AM   #7
67chevy1series
edited: not sure why it did a double post...
Old 06-14-2016, 07:43 PM   #8
clinebarger
Is the controller showing Closed Throttle/0% TPS at idle?
If the controller thinks your above Idle it will raise pressure, Anything above minimum Regulated Pressure will open the Forward Abuse Valve in the Valve Body.....Bypassing the Forward Clutch Accumulator, Giving a harsh Forward Engagement.
Also the output to the EPC should be around 1.00 AMPS at Idle.
clinebarger is offline   Reply With Quote
Old 06-16-2016, 04:26 AM   #9
67chevy1series
Did a new tune on the TCU and now the TPS is reading 00% at idle, and it doesn't kick very hard into gear. Thanks guys!
