06-13-2016, 08:17 AM | #1 |
Bendix Hydravac w/Dual Master
Hi all, I have a factory installed Bendix Hydravac on a 59 chevy 3100, with single master cyl. I am installing a new dual master cyl from Performance Online and wondering how to connect the factory hydravac. Or do I need to buy a booster/master already setup? Enclosed is a pic of the factory HydraVac and the new master cyl I plan on installing. Any help is greatly appreciated. thx
06-13-2016, 10:34 AM | #2 |
Hollister Road Co.
Re: Bendix Hydravac w/Dual Master
You can not use the hydravac with a dual master cylinder. You need a 7" dual diaphragm booster that will bolt to that bracket. depending on whether you are converting to disc front and or want under cab fill or remote fill on the firewall will determine which kit you should get. The bracket you have pictured above will not accept a booster. Its for a master cylinder only
06-13-2016, 02:46 PM | #3 |
Dodge motorhomes and many medium duty trucks with dual chamber master cylinders used dual Hydrovac boosters. Alternatively you might find a tandem HV such as this one:
Last week I was looking at a remote booster that used an hydraulic slave cylinder from a single master to actuate a vacuum assist dual chamber master. An interesting exercise that one... BTW, I'd love to get pictures, copies, or whatever of your brackets and lines to help with the HV installation in my own truck. |
06-13-2016, 03:37 PM | #4 |
Re: Bendix Hydrovac w/Dual Master
Well, I bought the wrong item, thank you for the advice. So I am returning the manual master/bracket to Performance Online. My plan is to pull out the factory HydroVac (I realize some of you consider that a "crime") and plumping and keep if for "another day".
Here is the new setup I purchased today. Its for a disc/drum system with 7" booster (from Performance Online). I also bought the residual pressure valves to maintain a small amount of pressure in the system which is needed when the master is below the level of the calipers and wheel cylinders. This installs to the existing brake bracket which is riveted on the frame, also pictured below (from an online parts photo). |
06-13-2016, 04:23 PM | #5 |
Hollister Road Co.
Unless your slamming the truck the valve won't be needed, But the kit is correct for what you want to do.
06-13-2016, 11:13 PM | #6 | |
. I may not be a smart man...... But I can't be the only one that think that right there is very sexy....Sp . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
06-14-2016, 06:41 AM | #7 |
No, you're not the only one. There was a guy selling them a few years ago for not too much $$. I don't know where to find one now.
06-14-2016, 09:55 PM | #8 | |
softpatch has gone soft in the head
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
