06-14-2016, 02:04 PM | #1 |
1966 C10 radiator choices
Looking for some input. Installing big block Chevy 396. Suggestions on radiator, fan shroud, fan blade, radiator hoses etc.
I will most likely be adding AC as well |
06-14-2016, 02:54 PM | #2 |
Re: 1966 C10 radiator choices
i run a Champion .... but with a BBC . would not recommend a cheap China Radiator . i say get a good US made Radiator like a BECool radiator http://becool.com/radiators i had a Becool in my 55 belair that had a BBC 502 in it and it never got hot even in stop and go traffic .... it ran at 180 the whole time . our trucks dont have the best air flow into the radiator so if your not trying to squeeze every drop of Horse Power out of the engine i would go with a factory fan shroud set up and a clutch fan set up .. also invest in a HV Water pump for the BBC ... 396 is a great motor lots of TQ . and very easy to make good HP numbers out of too ... they can spin some nasty RPMs if you ARP the bottom end.. also BBC's like to breathe so also go with a Single plane intake manifold .. unless your gonna be EFI ... i know this is more than you asked for but just trying to help with info .... Happy Truckin
06-14-2016, 04:03 PM | #3 |
Great info thanks
06-14-2016, 04:37 PM | #4 |
06-15-2016, 12:24 AM | #5 |
60-66 Nut
06-15-2016, 04:42 PM | #6 |
I run this one http://www.speedcooling.com/1963_196..._Radiator.html and am very happy with it.
06-15-2016, 05:51 PM | #7 | |
06-15-2016, 07:26 PM | #8 |
Moderator
I purchased a U.S. Radiator from Ricks Radiator in Azuza California, who I recommend using if you purchase a U.S. Radiator.
06-16-2016, 01:13 AM | #9 |
I have a mildly built 283 with a/c and a 4 speed manual tranny. One day last year when we had a 107 degree day here in the valley, I ran my truck up to the summit of the high Sierra Nevada range on I-80. I had a 276 rear gear back then (too tall, but I was making use of what I had available at the time) and I climbed the highway pushing my motor full throttle with the a/c on for long stretches at a time in an effort to run with modern cars at 65 mph. I had to do a lot of down shifting to keep my rpms up and tried to make the truck run hot....it never did. I even pulled off at the summit and let it idle while I looked at a map keeping the a/c running and I momentarily saw 190 degrees. But that was as hot as it got. Edit: I run a stock shroud and a 6 blade 18" motor driven fan with a heavy duty Hayden thermostatic clutch.
06-16-2016, 01:28 AM | #10 | |
06-16-2016, 08:42 AM | #11 |
This '71 has a 468 with an OEM big block aluminum radiator and dual electric fans. The '65 is running a 396 with a Griffin and dual Spal fan set up. Both cool very well.
06-16-2016, 09:18 AM | #12 |
Wow! I like that 65.. Im using a Champion radiator with Fbody electric fans cooling my LS2. Seems to work well thus far.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
06-16-2016, 09:21 AM | #13 |
Moderator
Don't forget to use the correct sending unit for the gauges being used.
06-16-2016, 10:35 AM | #14 |
I'm using the aluminum 4 core radiator by champion and an aluminum shroud with a electric fan. Also when you get ready to put air conditioning in I manufacturer Factory looking AC vents so you can use your Vintage Air 4 system with it
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
