10-01-2003, 03:29 AM | #1 |
i love summertime
Quick question-need quick awnser
i got another propane question, first off, i put a new rad in the truck today, the old one had a fitting for one of the heater hoses and the other went to the condenser (on propane) then intake, well my new rad doesnt have the fitting so im going to have to go to the water pump, the water pump is plugged with a massive set screw deal that has an allen head top on it, what i want to know is i have the one heater hose blocked off because the new rad doesnt have the fitting and i dont have the fitting to thread into the water pump. will this harm the condenser? i took the truck for a spin tonight after putting the rad in and when i got home i popped the hood to make sure all was good and antifreeze was dripping out of the condenser where the 2 haves join. and i also noticed the condenser was very cold. i think this should go away when i get the heater hose hooked up to the water pump because the anti freeze will flow. but until i do that, like tomorrow morning i need to get to work and ill get the parts on the way home kinda thing, but should it be okay to drive? what bad could happen if anything? hopefully someone can help me because its late now and im going to work first thing....thanks in advance
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
10-01-2003, 08:31 AM | #2 |
PROPANE
the propane system you are useing is a liquid withdrawal system. it needs the engine heat (from warm eng water ) to convert the liquid propane to a gas. they will run without a heat exchanger, but for how long is the question. if the engine dies on you, let it set till the propane turns to gas in the heat exchanger. this can take some time. leave the hood down as this helps the underhood temp warm the liquid propane. also driveing at a slower pace will help. more questions e-mail me troylv@cox.net or pm troylv
troy wilson |
10-01-2003, 08:45 AM | #3 |
CCRider
You won't go very far before it completely freezes up and quits running all together. I have seen forklifts freeze up and stop running just because the radiator was low on water. When you get it hooked to the water pump it will be fine. I hope you don't have far to go to work...like Troy said if it stops just give it a while to thaw out and it will go again for a while. I have never seen one damaged from freezing up and I worked on forklifts for years
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
10-01-2003, 10:09 AM | #4 |
i love summertime
thanks guys
10-01-2003, 09:29 PM | #5 |
i love summertime
well just got home from work, i limped the truck to lordco before work and got the fitting and they lended me the tools to do it there! didnt have time to wait for the truck to cool, had antiffreeze all over... got er done though and ram like a charm. good thing too b/c i got to work and about 2 hours later i cut the end of my finger off with a zip cut blade on a grinder, jumped in old trusty and beelined it to the walkin in..what a day
