06-14-2016, 05:02 PM | #1 |
12 Bolt Rear End
Made a start stripping the 12 bolt rear end I got for my 62. Got the drums off but Im buggered if I can see what holds the half/drive shafts in place.
Can anyone tell me how I get them out? |
06-14-2016, 05:09 PM | #2 | |
Re: 12 Bolt Rear End
06-14-2016, 05:09 PM | #3 |
Axles are held in with C clips located on the inner end of the axle (differential side gears). Pop the cover off of the back of the rear end, remove the cross shaft out of the differential case, then push the axle in toward the center of the differential. They will usually fall right out. Once the C clip is out you can just pull the axle out of the housing.
06-14-2016, 05:14 PM | #4 |
Thanks for that.
Im used to C clips on the outside. I'll take the cover off tomorrow and do that. I want to take the diff out anyway so thats not a problem. |
06-14-2016, 05:15 PM | #5 | |
06-14-2016, 05:18 PM | #6 |
The manual I have is for the 62 but the axle is from a 76. Didnt think about my missmatched parts when I bought the manual - Doh!
06-14-2016, 06:01 PM | #7 |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
06-15-2016, 12:27 AM | #8 |
60-66 Nut
06-15-2016, 02:41 AM | #9 |
Good thread John. At the moment, however, my goal is only to get the drive shafrs out as Im concerend I have an issue with one is that when I turn it it doesnt turn the diff and likewise when I turn the diff it only turns one shaft.
After that I do want to take the diff out to make the casing a bit liglter so I can clean and paint it. However, when it comes to working on the diff that thread will be invaluable. |
06-15-2016, 06:59 AM | #10 |
There is no issue with what you are seeing. That is how and open carrier works.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-15-2016, 07:14 AM | #11 |
"open carrier" Im not familiar with that term?
06-15-2016, 07:46 AM | #12 |
06-15-2016, 11:34 PM | #13 |
60-66 Nut
An open carrier as not a limited slip or posi. What you are describing is normal operation for an open differential.
