Old 06-14-2016, 05:12 PM   #1
JimmyOzone
JimmyOzone's Avatar
Suggestion for Trans Fluid for '70 350 C20 Automatic Trans
Hi everyone. I need to add about a pint or so of transmission fluid to my factory '70 C-20 350 V-8 automatic trans. Does anyone have any suggestions based on what works best for them? The manual says to use 'DEXRON', but I noticed there are different types of it. I was looking in the local Autozone and they have multiple options. http://www.autozone.com/motor-oil-an...smission-fluidMy vehicle is original and has about 160,000 miles. I really appreciate everyone's feedback.
You can't spell Olive without Love
1970 C-20 350 V-8 Daily Driver
JimmyOzone is offline   Reply With Quote
Old 06-14-2016, 05:38 PM   #2
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Suggestion for Trans Fluid for '70 350 C20 Automatic Trans
Dexron 3 is what i use in my th350, i used the aap brand( basically vavlaline) but any brand besides the stuff you would get at a gas station would be fine.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 06-14-2016, 06:01 PM   #3
JimmyOzone
JimmyOzone's Avatar
Thanks BlackedOut67shorty
Old 06-14-2016, 06:10 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I also use Dexron III. Last time I was at my local Napa store, I saw some other grade of Dexron but I don't recall what may have made it different.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 06-14-2016, 06:14 PM   #5
jocko
jocko's Avatar
needs to be at least a dex/merc variant - specific to GM auto trans. Note that some others are Ford/T5 only. If you check the owner's manual, it will give the the ATF equivalency specs, however the ratings have long ago been superseded. You can check to see what today's equivalent is for the original manufacturer's recommendation, but, bottom line - you just need a dex/merc type for a standard TH350/TH400.
Old 06-14-2016, 06:46 PM   #6
JimmyOzone
JimmyOzone's Avatar
Thanks Stocker & Jocko for your input. They didn't have a Dextron III, so I got Dextron VI for GMs which says it satisfies the requirements of III.
http://www.autozone.com/motor-oil-an...id/930140_0_0/
Old 06-14-2016, 07:03 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Suggestion for Trans Fluid for '70 350 C20 Automatic Trans
I think you just jogged my memory.... that Dexron VI is a synthetic blend and a bit more expensive than the Dexron III that I bought. Possibly better, esp. for extreme applications.
- Mike -
RIP El Jay
Old 06-15-2016, 01:38 AM   #8
Highlander72
I always used Type F in my Chevy slushboxes. Slightly less slippery than Dexron.
'72 C10 Highlander | '69 GTO | '06 VFR800 | '96 XR250
Highlander72 is offline   Reply With Quote
Old 06-15-2016, 09:37 PM   #9
turp mcspray
turp mcspray's Avatar
x2
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-18-2016, 10:31 PM   #10
Harley03joe
Will This Work In My 71 C 20 350 Turbo Transmission ?
I'm Just Changing The Oil In The Pan?
Thank You For Your Input
Harley03joe
Harley03joe is offline   Reply With Quote
