06-14-2016, 06:17 PM | #1 |
Fessler racing 385 and 700r4 trans for sale
I am selling the motor and trans out of my truck which is a 69 shortened c-10 the motor and trans only have 200 miles on them and 5 dyno passes before the motor was in the truck. This motor was built by Shane Fessler at Fessler racing engines he said it is the baddest sbc he's ever built under 400 ci I have dyno sheets and dyno videos for the motor and he will also talk to you and tell you more about the motor money wasn't an issue in this build I bought the best I could get with the motor and trans motor was broke in and tuned on the engine dyno and fires first crank and pulls hard past 7500rpm and idles at 1000rpm Shane specializes in dirt track and modifiers and you can tell in this build very fast high revving small block with break neck throttle response! I am wanting 5000$ for the motor turn key from carb to oil pan all the accesories and msd setup I have well over 10k in this motor and I am looking for 2500$ for the trans setup I am over my going fast days and would like to get an ls motor and trans pullout from something that will be more driveable I am open to all offers even low ball feel free to message me or call me at 314-775-6454 I have lots of pics and videos but am not good at uploading them on here so let me know if you would like pics and videos motor and trans are still in truck and running
Motor details : 385 ci sbc singe rear main seal 10.6 to 1 compression 4.060 bore srp forged Pistons 3.75 lightened forged scat crank Scat forged I beam 750 hp rods Cncd 210 afr heads titanium retainers and locks have flow numbers All arp upgraded hardware Arp head studs Stud girdles Smith bro pushrods Custom bullet solid roller cam .688/.688 257/261 Comp cams pro magnum chromoly 1.6 roller rockers Custom one off solid roller lifters made by a guy in Florida I forget his name Super victor Jr that's been ported and flow benched with heads piece of art Custom Fessler racing Holley 750 hp carb Msd pro billet distributor and digital 6 box Master power chrome alternator with billet bracket Motor was setup to run nitrous cam is good for a 400 shot but I was only going to spray 200 per Shane's advice on a stock block Trans specs: 700r4 with the thick case Billet input shaft and pump assembly Hardened output shaft Sonnax smartshell Billet servos 5 gear planets Sonnax hp drum Sun gear assembly Trans go shift kit Sonnax servo assemblies 2nd/4th PATC mega raptor 2 billet converter rated at 1000 hp Etc. there are a lot more parts in it but that's what I remember ,Every part that is made to upgrade this trans it was put in it I have a full build sheet with receipts cost 3700$ total with labor was setup to handle a 250 shot of nitrous out of the hole and over 800 hp built by Gary Walsh at quality transmission Last edited by 69restomod; 06-17-2016 at 05:03 PM. |
06-14-2016, 07:35 PM | #2 |
Re: Fessler racing 385 and 700r4 trans for sale
I'm building one similar to this... What kind of numbers it make?
06-14-2016, 09:00 PM | #3 |
I'm looking for the dyno sheets but I think my trans builder has them if I remember right I think it made around 550 at 7200 and 475 lb ft at around 5200 but had a bad ass curve with 400lb ft from 3500 past 6200 and 500 hp from 4200 past 7500! My engine builder says his dyno reads 50 hp low but I didn't take that into consideration lol
06-14-2016, 09:27 PM | #4 |
Ya that's what I figured 550-600hp great engine for someone and good luck on the sale!
06-14-2016, 09:32 PM | #5 |
Thanks man I was hoping for 600 hp but I had the option of 12.6 to 1 or 10.6 to 1 to utilize the quench of the heads and I wanted to run on pump gas on the street so we went with 10.6 and we went with a nitrous grind on the cam I think If we would've done a more n/a cam and more compression it would've hit the 600++ mark! But I love the motor it absolutely screams!! I just changed my mind on what I wanted lol everybody that has rode in the truck can't get over how hard it pulls up top and keeps pulling through the gear it's like a freight train haha
06-16-2016, 05:31 PM | #6 |
Haven't had any interest in the motor and trans , I'm dropping the price to 7500$ total for motor and trans 5000$ for the motor turn key with all the accessories and carb and msd setup!! And 2500$ for the trans or will trade someone for a 6 speed setup straight up!! I am taking a huge hit on selling this stuff it is literally brand new and best parts money can buy but I'm ready to move on!
06-17-2016, 06:02 PM | #7 |
Here is a picture of the trans
06-17-2016, 06:05 PM | #8 |
Picture of the carb
06-17-2016, 06:12 PM | #9 |
Picture of motor in truck
06-17-2016, 06:21 PM | #10 |
One of the dyno sheets
06-18-2016, 10:29 AM | #11 |
Hell of a buy! Good luck
06-18-2016, 10:53 AM | #12 |
Somebody is gonna get an awesome deal!
06-20-2016, 04:49 PM | #13 |
Will throw in my hole fuel system if somebody buys the motor it is a quickfuel billet 175 that has a built in regualtor and is good for 750hp with -8an inlets and outlets , will also include the race style fuel filter it's a long cylinder style with changeable inserts that I just changed has -8an inlet and outlet and will include all the black braided -8 an line and fittings maybe even work out a deal on my sumped fuel cell with sending unit for our trucks!! This is truly a turnkey setup motor has great drive ability on the street will sit at stoplight and doesn't buck motor has never gotten over 180 degrees will sit in traffic no problem don't let the .688 solid roller scare you away this motor was built and tuned for the street! You couldn't build this motor or put together a setup like this for even close to what I'm selling it for, everything is made to work with each other!
