Old 06-16-2016, 12:18 PM   #1
Sandtrap9072
Sandtrap9072's Avatar
Fender Badge Removal/Install GMC JIMMY
So, i am thinking of buying a new set of emblems. How easy/Hard is it to replace the fender emblems? Do i need to take the fender off or can i get to the nuts by just removing the wheel well? I have read a couple different posts saying it cant be done without taking the fender off, is this true?
Sandtrap9072 is offline   Reply With Quote
Old 06-16-2016, 02:36 PM   #2
landy
Re: Fender Badge Removal/Install GMC JIMMY
I've read that too. I tried accessing mine, but couldn't reach one of the fasteners.
landy is offline   Reply With Quote
Old 06-16-2016, 04:50 PM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I cant remember on mine, but I'm next to positive you can easily reach the nuts if you drop the fender well.
Tom Vogel is offline   Reply With Quote
Old 06-16-2016, 09:39 PM   #4
Speedway16
They are pretty easy to get to if you remove the inner fender.
Speedway16 is offline   Reply With Quote
Old 06-17-2016, 11:54 AM   #5
JJH Jimmy
JJH Jimmy's Avatar
I thought that it kinda sucked going through the inner fender. The trick was to get the speed nut on the stud. I lined a box end wrench with masking tape So the nut would stick to it.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-17-2016, 12:55 PM   #6
pound41
Most people when they replace them don't use the regular nuts. They use the barrel nuts the hollow insert that expands when the stud goes in it
pound41 is offline   Reply With Quote
Old 06-17-2016, 01:46 PM   #7
Sandtrap9072
Ok, so its definitely do able. looks like i am going to order me some new emblems. thanks for you help guys!
