06-16-2016, 02:00 PM | #1 |
Does anyone make the plastic gasket for-
Does anyone make the black plastic gasket for the Chevrolet script on the tailgate band. my truck is a 1986 Silverado It actually goes under the script and adds high lights to it. Mine is broke in thirds and I'm missing the first part. Or has somebody made them out of vinyl, that would work also.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan Last edited by 1970pelle; 06-16-2016 at 02:01 PM. Reason: added info |
06-20-2016, 11:28 PM | #2 |
Re: Does anyone make the plastic gasket for-
Here is a picture of what I need, if my discription isn't very clear or just plan bad. I did confirm the parts are in deed discontinued. So I'm going to see if I can get a few made of vinyl decal in semi gloss black. If they work I'll have a few if somebody needs one, for a donation.
I thought it may be different if your truck was a color red and rather than a black gasket, use a red one. It may look cool. Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
06-21-2016, 10:20 PM | #3 |
I don't know where you could find them but maybe as a suggestion, you could find a suitable material and get a sign/decal shop to cut them nice? Maybe if the material was not too thick. Then you could go with coloured like you mentioned?
-Cody |
06-22-2016, 01:05 AM | #4 |
That's what I'm going to try. And keeping in mind copyright issue's. This is something I wouldn't want to have made and then try and sell.
Ken
06-22-2016, 03:30 AM | #5 |
Post Whore
