Old 06-16-2016, 10:03 PM   #1
Kaaso
1966 C10 w/factory air possible swap to aftermarket system
I have a 1966 C10 with factory air. I am thinking about swapping it to an aftermarket system. Does anyone have any suggestions on the system they have personally used? I really want to keep the dash looking the same as it does now and use the original vertical slides and pull knobs.
Thanks in advance for the info.
Kaaso is offline   Reply With Quote
Old 06-17-2016, 09:50 AM   #2
65Gregg
65Gregg's Avatar
Re: 1966 C10 w/factory air possible swap to aftermarket system
Vintage Air SureFit will do the trick, your dash will look OE.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 06-18-2016, 08:14 AM   #3
Kaaso
Thank you 65Gregg.
Old 06-18-2016, 01:19 PM   #4
pimpston65
pimpston65's Avatar
Originally Posted by Kaaso View Post
Thank you 65Gregg.
you gonna post the old factory ac stuff for sale???
pimpston65 is offline   Reply With Quote
Old 06-18-2016, 01:35 PM   #5
Kaaso
Already have a buyer. Thanks tho.
Old 06-18-2016, 04:21 PM   #6
corvettejim1968
corvettejim1968's Avatar
when you do the vintage air it has 4 outlets so I created some outer dash side vents that have a factory look. plus nsb29 makes the inside dash air box that will work with the vintage air.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 06-18-2016, 05:20 PM   #7
Mathew21
Mathew21's Avatar
Winston is always on the hunt.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 06-18-2016, 05:58 PM   #8
pimpston65
pimpston65's Avatar
always in all ways!!!
Old 06-19-2016, 12:05 AM   #9
oldies1938
Im going with the vintage air swap still not done but making good progress
oldies1938 is offline   Reply With Quote
