Old 06-17-2016, 10:46 AM   #1
Heydon
Heydon's Avatar
Longer wheel studs
Hi
Making slow progress on the C10 and having fun.
Truck runs later chevrolet drums and discs- now 5 stud.
I need to fit 10 mm wheel spacers for clearance. This means I need longer wheel studs.
Having removed them and measured them it looks like I have Dorman 610-138 and 610-159 studs. I am unsure if these are "Clipped" versions or not as I don't know what "clipped" actually is.
Dorman don't list a longer version that is exactly the same knurl diameter etc.
Any idea what stud I should use to replace my current ones or do I just need to buy better offset wheels?
Lifetime Cal look VW fan on a new Chevy truck shaped adventure....
1965 C10 SWB Fleetside, LT1
1967 VW Bug 2332cc
Heydon is offline   Reply With Quote
Old 06-17-2016, 01:13 PM   #2
61K10
61K10's Avatar
Re: Longer wheel studs
ck out some studs for drag racing. they are 3" long (you could trim to your length) just a thought.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-17-2016, 02:47 PM   #3
jtrichard
If your are NOT married to the 1/2-20 you could use these and enlarge the holes in the half that take the smaller knurl studs http://www.dormanproducts.com/p-3541-610-182.aspx
"CLIPPED" is a flat side or two on the head yours are NOT clipped
jtrichard is offline   Reply With Quote
Old 06-17-2016, 04:48 PM   #4
Heydon
Heydon's Avatar
Thank you both- much appreciated and think that might work.
Taking your suggestions... how would the following alternatives be?
One has same knurl diameter but slightly shorter knurl with longer stud
One has slightly wider knurl diameter and is longer
610-528.1
610-379.1
Can I just double check that my current studs arent clipped and have same style head as the above..pic below.
Thanks again.
1967 VW Bug 2332cc
Old 06-17-2016, 10:02 PM   #5
jtrichard
The 528 is a METRIC with .650 knurl and 1 3/4 under head length (UHL).... The 379 is 1/2-20 with a .620 knurl and UHL of 1-15/16 length BUT it has about 1/4" that is NOT threaded so one or both may not be long enough for your needs .....THE 138s you have now have UHL of 1-17/32 (1-1/2")
Old 06-18-2016, 02:50 AM   #6
Heydon
Heydon's Avatar
Ahhh. Thank you... my error. I swapped digits on one stud. Meant to say...
610 379
610 258!!!
The 379 should have 3.4 mm more than my current stud, which should be ok with an 8mm spacer- just.
Does that sound about right now?
1967 VW Bug 2332cc
Old 06-18-2016, 11:53 AM   #7
jtrichard
To me it looks like the 379 even though its longer, has 1/4" less thread because of the "pilot" tip making it effectively the same length or even slightly shorter then what you have now
IF 3.4 mm would get you out far enough then these (or ones like it) may be an option for you instead of the studs http://www.ebay.com/itm/1pc-1-2-CHRO...5UPoIY&vxp=mtr
Old 06-20-2016, 06:49 AM   #8
Heydon
Heydon's Avatar
Thanks- for checking and for the advice on the nuts- that's a clever solution! ;-)
I do think the 379 get me 3.175 mm more of thread- but you are right it is close and if the cad is incorrect then I have some spare studs on my hands. ;-)
The Dorman cad drawing that shows the unthreaded end is .21 of an inch leaving 1.75 inches of thread.
My current stud has 1.625 inches of thread.
Going to try those nuts as well and learn from the outcome... had never seen ones like that before.
Much appreciated. ;-)
1967 VW Bug 2332cc
Old 06-20-2016, 01:00 PM   #9
old cool
Smile Re: Longer wheel studs
On my read hubs (drums) for a 2wd, six lug, 1966 gmc, I used Moroso 8 grade racing studs. Obviously needed to cut to appropriately length. Knurls were micro sized bigger than stock studs but worked well with a little muscle.
Double check and compare, but the numbers I show on some old paper work are:
(MOR-46160) size=7/16 - 20 - .560
old cool is offline   Reply With Quote
