![]() Join Date: Nov 2013
air cleaner clearance question
a question for you wizards here.
I have my 83 k3500 mostly back together now, and I am running into an unforseen problem. I have an aftermarket aluminum intake that is a bit taller than the factory one. This truck also came with a super tall air cleaner housing that will be too tall for the hood. Is there a shorter set up? It still has the spark arrestor inside which is tall. I know there are shorter filter elements. is there an existing lid i can find that is the same diameter as the housing? it has vacuum attachments and a switch i cant eliminate due to smog, so I am at a loss.
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
Re: air cleaner clearance question
Which intake did you get? I am running a Quadrajet on an edelbrock performer with the tall element and just clear the hood.
