How do you install gas tank grommet
Hello,
What is the easiest way to install the gas tank grommet? Thanks! |
![]() Join Date: Sep 2010
Re: How do you install gas tank grommet
The easiest way is to pull the tank... But pull the seat... cut the old one out... you will need a trim tool... and alot of patience and pull it through...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
If your tank is already installed lube your new grommet with dish soap and it will work in with a little hand work .My first one did not last long and I did not want to remove the tank when I got a good grommet.
![]() Join Date: Dec 2013
X2, all I had on hand was WD40, cut the old one out and slid the new in. No problem, don't need to remove the tank.
![]() Join Date: May 2012
still either way it is still not easy ........ good luck
Moderator
![]() Join Date: May 2007
Cut the old one out, lube the new one with wd40 and pop it in. 5 minute job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
X2 on the dish soap.
I used a screwdriver to carefully work it in to place. Keep it soaked in dish soap and it only takes a few minutes
71 swb 350/4sp manual 5/7 static drop |
silly question
......tank grommet orientation..... cone "in/down" or cone "out/up"???
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
Warming the grommet up in the sun a bit first never hurts either. Makes it a tad more pliable.
#10 | |
BlahBlahBlah
![]() Hopefully your grommet is a good quality one like Wes sells at Classic Heartbeat. Those grommets are sooo nice, and pretty darn easy to install.
Maybe for you CA guys!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
Cone out/up.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#13 |
#14 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
http://www.classicheartbeat.com
#15 |
Man, I just tried doing this yesterday with the tank in. Lubed up or not, warm, cold, whatever... it is a pain in the neck to do with the tank installed. I got the grommet from Wes at Classicheartbeat and it is solid heavy duty rubber. Not the squishy pliable stuff from the parts store. If you can, remove the seat and tank. Put the grommet in, then slide the tank through it. I used windex to lube it up. After 30 minutes of trying to poke the new one in place with a screwdriver i just pulled the tank.
#16 |
![]() Join Date: Feb 2009
In addition to dish soap or something like, seems to me a heat gun is in order.
I've heard that though the company claims otherwise, typical WD40 is bad for rubber, because "it contains petroleum distillates (paint thinner)". You're likely fine, but I try to avoid it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-07-2018 at 01:21 PM. |
#17 | |
But if I had cut it, I'd have been hooped! So just make sure...
#18 |
Moderator
Classicheartbeat sells replacements that have a warranty
#19 |
For those of us without much sun these days...boiling it in water for a minute will do the trick and won't risk scorching it. Don't forget your gloves!
AND 71Chev... is right, no petroleum based oils just to be on the safe side. Soap or synthetic oil//grease only. Petroleum will speed up the decomposition process.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#20 |
Well, at least remove the grommet from your sub-zero garage and bring it into your house for a few hours before trying to work with it! I forget about the rest of the world when I'm basking in the sun out here in SoCal.
#21 |
Moderator
I used wd40 on it almost 10 years ago. Rubber hasn’t deteriorated yet
#22 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#23 |
Moderator
I guess I’m hosed
#24 |
Following. Doing this in the near future
