Old 06-17-2016, 09:44 PM   #1
63Ton
C30 Dually Front Rotors
Does anyone know a place that carriers front dually rotors for a 71 C30? Or will one from a 73 -91 work?
63Ton is offline   Reply With Quote
Old 06-17-2016, 10:06 PM   #2
old Chevy guy
old Chevy guy's Avatar
Re: C30 Dually Front Rotors
Haven't found any aftermarket ones. Gave up and swapped to newer 73-87 ones. Easy swap. On your 71-72 t c30 you can swap out the spindle direct bolt on. Same ball joints, same tie rod ends. Bolts right on the use the newer rotors and calipers and the flexible brake lines.i re routed my brake lines like this .
old Chevy guy is offline   Reply With Quote
Old 06-17-2016, 10:16 PM   #3
old Chevy guy
Size:  58.6 KB this is all together.
Old 06-17-2016, 10:16 PM   #4
kwmech
I changed mine over as well. The 'newer' rotors are thicker at 1.5'' instead of 1.25
Old 06-17-2016, 10:19 PM   #5
old Chevy guy
The newer setup uses the JB 8 style caliper. The newer rotor won't work with the current setup.
Old 06-17-2016, 10:44 PM   #6
old Chevy guy
Did you have any trouble with the calipers rattling at all?
Old 06-18-2016, 02:07 AM   #7
kwmech
Not at all. I swapped everything from spindle out, went with new rotors and calipers. Had a custom brake lines made also. I did this in my 69, so I was also converting from drum
