Old 06-17-2016, 10:37 PM   #1
svr
svr's Avatar
57 door hinges?
Are the left and right upper door hinges the same, just turned over? Pulled mine for new pins and bushings and have 2 different styles of bushings and one side has the spring arm on the top and the other is on the bottom. Also is there supposed to be a roller of some kind on the pin that presses on the spring arm. Now wondering if i should have ordered new hinges. Thanks
svr is offline   Reply With Quote
Old 06-18-2016, 05:11 PM   #2
Coupeguy2001
Coupeguy2001's Avatar
Re: 57 door hinges?
The ramp and springs should be on the bottom. Looks like someone flipped one upside down, and used it on the wrong side.
Coupeguy2001 is offline   Reply With Quote
Old 06-19-2016, 01:18 PM   #3
Jemezcrusher
Re: 57 door hinges?
No rollers. Just pocket housing, arm, and pins
Jemezcrusher is offline   Reply With Quote
