Old 06-18-2016, 01:54 AM   #1
Jason7121
Jason7121's Avatar
71 C10 6.0 LS ground up build
Finally bought myself a c10 about five weeks ago and drove her home. This brings back great memories of my first c10 i owned in high school and my first date with my now wife of 19 years. Couldnt wait to get started on the ground up build. A good friend and i got it tor down to rolling chassis on a friday night now the fun begins.
Jason7121 is offline   Reply With Quote
Old 06-21-2016, 02:43 AM   #2
Jason7121
Jason7121's Avatar
Re: 71 C10 6.0 LS ground up build
Got frame all done and previous work of shortening frame redone before powder coating. Sent frame out for chassis black powder coating along with front end componets.
Old 06-21-2016, 08:25 AM   #3
RRR18
RRR18's Avatar
Watchin
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 06-23-2016, 12:37 AM   #4
Jason7121
Jason7121's Avatar
Got roller assembled used eec 4/6 drop kit with there trailing arm crossmember and gen 3 ls mounts. Got rear shocks relocated and pan bar from eec setup. I rebuilt entire rear differential and installed 3.73 gears with yukon posi unit. Sand blasted and painted rear diff.
Old 06-23-2016, 08:29 AM   #5
Bubba4spd
Bubba4spd's Avatar
Awesome start! Hang tough.
Bubba4spd is offline   Reply With Quote
Old 06-23-2016, 09:28 AM   #6
TexasLS1
TexasLS1's Avatar
Awesome! Watchin.....
TexasLS1 is offline   Reply With Quote
Old 07-07-2016, 11:55 PM   #7
Jason7121
Jason7121's Avatar
Had some time with the holiday weekend so I rebuilt a 4l60e with heavy duty sprag sunshell and 5 pinion planetary gears. Used a transgo shift kit and high energy clutches. Painted and clear coated trans and installed aluminum pan. Got brake lines ran and flared. Feels good to have a major componets finished!
Old 07-25-2016, 03:24 PM   #8
Jason7121
Jason7121's Avatar
Been awhile since I updated the build. Took lq4 engine apart and had valve job done. Installed a z06 corvette camshaft and valve springs. Assembled and painted motor. Ready for install now
Old 07-25-2016, 05:26 PM   #9
tucker69
tucker69's Avatar
Keep up the good work... Just finished my LS swap and let me tell you,,, you want regret it once your done and have all the demons worked out...Casey
tucker69 is offline   Reply With Quote
Old 07-25-2016, 06:46 PM   #10
Jason7121
Jason7121's Avatar
Thanks. If you don't mind send me a picture of where you put ecm and hoe it looks under the hood!
Old 07-26-2016, 12:24 AM   #11
tommys72
tommys72's Avatar
Looking good so far
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-26-2016, 06:02 AM   #12
GR8-68
GR8-68's Avatar
Awesome build, progress is looking great
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-26-2016, 07:34 AM   #13
notsolo
notsolo's Avatar
Another- you made that look easy. Quick work, Chassis Looks fantastic. Carry On.
notsolo is offline   Reply With Quote
Old 07-26-2016, 03:14 PM   #14
Jason7121
Jason7121's Avatar
Thanks guys slowly but surely getting there.
Old 07-30-2016, 01:58 PM   #15
Jason7121
Jason7121's Avatar
Got motor and transmission sitting in frame last night now cab needs to be set back on for mock up of ac etc.
Old 07-30-2016, 11:50 PM   #16
chevy71c10
chevy71c10's Avatar
Very nice build! You are getting busy and doing a great job!
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 07-31-2016, 11:33 AM   #17
knomadd
knomadd's Avatar
What did you do for the motor mounts/perches on the frame? Frame is looking good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-31-2016, 06:22 PM   #18
Jason7121
Jason7121's Avatar
I used perches and mounts from ece there gen 3 mounts come complete with all hardware etc. Mounts have about an inch of movement forward or rearward. Using there trans crossmember as well. Hope that helps.
Old 08-05-2016, 09:39 AM   #19
Jason7121
Jason7121's Avatar
Got cab back on and checked clearance. Fit like a glove now time to mock up brake booster and ac system.
Old 08-06-2016, 09:25 PM   #20
jeh
jeh's Avatar
I'll be watchin'
This looks like an awesome build!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 08-12-2016, 10:40 PM   #21
Jinxy81
Looks familiar
Following, good looking build.
Jinxy81 is offline   Reply With Quote
Old 08-13-2016, 12:49 AM   #22
Jason7121
Jason7121's Avatar
Thanks everyone for the compliments. I got alot done sinow last post. I'll have to take some more pictures.
Old 08-13-2016, 10:15 PM   #23
xtremedurb00
xtremedurb00's Avatar
Looks great so far! Can't wait to see more. I'll be following this one. I'm also dropping in a LQ4.
1971 C-10 SB 2WD - Project Money Pit
Project Build: http://67-72chevytrucks.com/vboard/s...d.php?t=606875
xtremedurb00 is offline   Reply With Quote
Old 08-14-2016, 12:15 AM   #24
Jason7121
Jason7121's Avatar
Thanks what year Lq4 are you doing and where are you mounting the ecm?
Old 08-15-2016, 12:34 AM   #25
Jason7121
Jason7121's Avatar
Smile Re: 71 C10 6.0 LS ground up build
Got interior taken out this weekend and was happy with floor and cab condition. Also finished up modification to my Ls wiring harness. Also got steam port tapped into the waterpump.
