Old 06-18-2016, 06:48 PM   #1
tjsblazer
tjsblazer's Avatar
Front tow hook mount direction (69-72 style) ??
OK, my Blazer never had front tow hooks but I'm adding them. I have the 69-72 style where the ends of the left and right side curl in opposed directions.
Question is, which is left and which is right? Which way do they curl when mounted? A picture may be even better if you have it.
Thanks for the help.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-18-2016, 08:50 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Front tow hook mount direction (69-72 style) ??
Sorry Jeff no pic but the hooks open to the rear of the vehicle (so as tow chain/strap doesn't detach when under tension).
Coming home pics look great btw!!
Old 06-18-2016, 09:13 PM   #3
tjsblazer
tjsblazer's Avatar
Pete. I didn't describe very well. I mean which way does the curl of the end go. Towards the outside of the truck or the inside towards each other.
You know I think I better get mine out tomorrow and hold them up against the frame holes. Maybe they can only go on one way.
Yes. Was great to get it back home for sure. Thanks!!‎
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-19-2016, 10:04 PM   #4
1972 Jimmy
1972 Jimmy's Avatar
I have the curled end pointing to the outside of my truck. If you have them point to the inside, there is very little clearance between the frame and the tip of the hook.
1972 Jimmy is offline   Reply With Quote
Old 06-19-2016, 10:09 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good question - I'm really not sure and can't reliably recall the orientation of the set on my old K10. Only have 72 specific examples now.
Old 06-19-2016, 11:15 PM   #6
67-72trucks
Pic of my passenger side tow hook.
67-72trucks is offline   Reply With Quote
Old 06-20-2016, 01:15 PM   #7
bluek5
bluek5's Avatar
Curious about this as well. I have installed four sets on my outfits. Pointed the tips to the outside on all of them.
bluek5 is offline   Reply With Quote
Old 06-20-2016, 02:31 PM   #8
ClassicStyle
ClassicStyle's Avatar
My highlander point outside, my last 72 had hooks pointing the same direction, driver side inside, pass side outside
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 06-20-2016, 02:37 PM   #9
bluek5
bluek5's Avatar
I assume that your 72 had the extreme bend hooks?
Old 06-20-2016, 06:46 PM   #10
tjsblazer
tjsblazer's Avatar
Thanks guys for the pictures and input. I didn't install but I held them up to the frame this weekend. It does make the most sense for the tips pointing outboard as in the picture 'bluek5' posted.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-20-2016, 06:50 PM   #11
bluek5
bluek5's Avatar
Jeff,
Does your frame have holes? If you need measurements. I think I can find a post a link to a good thread on locating them.
Paul
Old 06-20-2016, 07:05 PM   #12
bluek5
bluek5's Avatar
Just in case.http://67-72chevytrucks.com/vboard/s...d.php?t=375734 Also a better picture without full sunlight.
Old 06-20-2016, 07:46 PM   #13
ClassicStyle
Yea that's them, just looked at the picture of it, didn't remember them being
Old 06-20-2016, 07:47 PM   #14
tjsblazer
tjsblazer's Avatar
Thanks Paul. No I have the holes. It all makes sense once I dug them out and held them in position. I had just never seen an actual set mounted before so the picture was helpful.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
