1950 gas pedal
1950 gmc 3100 im having trouble finding a gas pedal that works ive installed new floor boards /350 sbc everything ive tried hits the hump on fire wall what are you guys using thanks
![]() Join Date: Aug 2012
Re: 1950 gas pedal
I'm guessing you are trying aftermarket pedals like Lokar, etc? Have you tried the stock pedal if floor mounted works for your build? Hard to beat the stock fit!
Build Thread: "Marvin" (1953 3100) |
Re: 1950 gas pedal
From experience you have a seriously hard time hooking up the linkage to a V8 from a stock pedal. That is even if it will fit in the truck anymore with the mods to the floor for the trans hump. I've tried several pedal setups over the years and the last one was a Mustang II Pedal that came from a parts rig I had. I had to bend the upper arm a bit if memory serves right and drilled a hole in the firewall for the cable.
A guy might be able to rig the stock pedal and part of the original throttle rod up with a bellcrank to work the linkage but that is a lot of fabricating before you are done along with some serious engineering to get the ratios right on the linkage to work the carb to full throttle.
Re: 1950 gas pedal
ive got a stock pedal hooked up to my 327. if my memory is correct, the linkage kit I used came from classic parts. check it out
Re: 1950 gas pedal
This is one I found for TF trucks that might be made to work. http://www.classicparts.com/1955-59-...nfo/89%2D651/#
thanks for the info
Re: 1950 gas pedal
I used a gas pedal and cable from a GM suburban. Pretty much the same one is used in vans and pickups. Bought two, used one to extend the arm of the second one. Bolt in, connect cable and your done. Cost me $5.00
Re: 1950 gas pedal
mr 48 - that is the one I have - just had to make sure the pedal has the ball socket on the back
Re: 1950 gas pedal
FiftyTwo, What generation suburban?
Thanks |
Re: 1950 gas pedal
Mid-90's Suburban. A GM pickup or van works well too.
