Old 06-19-2016, 11:44 AM   #1
thatcherkozal
thatcherkozal's Avatar
72 K5 496 Transmission?
I have a 72 K5 that was originally a sb 350, but that wasn't quite enough fun for me. So I bought a stock 454 and swapped it but kept the 350t (just a little beefed up) And now the 454 isn't enough for me. So I tore it out and bored it out and built myself a mild 496 stroker. But now I need to put it back in, and I know the 350t is not a good idea for a transmission... What do ya'll think would be a good option instead?
thatcherkozal is offline   Reply With Quote
Old 06-19-2016, 03:06 PM   #2
AJs72K5
AJs72K5's Avatar
Re: 72 K5 496 Transmission?
Staying with automatic? A 700R4 or 4L60 won't stand up to the torque of a 496 long term (or possibly short term). You're looking at either a 400 or a 4L80.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-19-2016, 04:38 PM   #3
thatcherkozal
I would prefer to switch to a manual, but don't know how much of a pain/extra work that would include
Old 06-19-2016, 06:04 PM   #4
tjsblazer
tjsblazer's Avatar
NV4500 is a decent option in a 5 spd. They put them behind everything including diesels. It is a pretty common swap. I did it in my build. It wasn't that difficult.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-21-2016, 09:23 AM   #5
Mike C
Mike C's Avatar
If money matters to you as much as me, the only answer is an SM465 and the NP205 IMO. With the torque of the 496 you can gear the axles to cruise whatever RPM you prefer and the granny gear gives you good off-road chops still. Any truck through the early 80's with the SM465/NP205 would be a good donor. Shouldn't be more than $500 worth of transmission parts. Driveshaft mods will most likely be needed as well as clutch linkage fabrication because of the non-OEM placement of a big block in the 4x4 trucks.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-21-2016, 06:29 PM   #6
13jraven
13jraven's Avatar
You could go with a NV4500 and a keep your stock TC. But you will need a bunch of adapters from AA, hydro pedals and all the clutch parts.
http://www.advanceadapters.com/produ...kit-replth350/
Or go for a 4L80e. But you will need more spendy adapters from AA to keep your stock TC. Or you can find a NP205 for a 4L80e.
http://www.advanceadapters.com/produ...h350-or-sm465/
John
13jraven is offline   Reply With Quote
Old 06-21-2016, 07:45 PM   #7
tjsblazer
tjsblazer's Avatar
Or you can get a round pattern NP 205 out of a '85-91 one ton. They are a direct bolt without an adapter. Need a short input and a little bit of machining on the NV4500 tailstock.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
