Old 06-19-2016, 05:10 PM   #1
uncle
3/4 ton coil spring axle perch ?
Does anyone reproduce the perch for 3 1/2 axle tube on coil spring rear?
uncle is offline   Reply With Quote
Old 06-19-2016, 05:31 PM   #2
Chknlyps2
Re: 3/4 ton coil spring axle perch ?
Captainfab makes ones for GM 14 bolt and Dana 60, not sure the tube diameter on a 60 but I think a 14 bolt is real close to 3 1/3 inch diameter. Here is the thread, PM him and see if he makes a 3 1/2 in. http://67-72chevytrucks.com/vboard/s...d.php?t=620836
Chknlyps2 is offline   Reply With Quote
Old 06-19-2016, 06:54 PM   #3
uncle
Thank you. I tried the search but evidently not the correct key words.
Old 06-19-2016, 08:29 PM   #4
dennislbrooks
dennislbrooks's Avatar
looking
http://www.cutthroat4x4.com/catalog/...a38knujd1l3lt0
maybe
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
