Old 06-19-2016, 09:47 PM   #1
cknfrmr
help with front brake drum removel
Posting on main forum due to did not know how to move from projects. Sorry
I am having great difficulty getting the front drums off my 69 C10. What I have done so far is sprayed them with many different brands of lubricant and rust freeing junk over the last week. Have beat on them from front, sides and rear with no movement at all. Also tried heating them up many different times. Have also backed off the brake pad spanner. Even drilled out the retaining posts for the brakes shoes thinking that if there was a groove wore in them it would let the whole thing come off as whole. None of the above things have done anything. Does anyone know of something I've overlooked or missed? What have I done wrong. Any suggestions? Would like to thank you in advance for your time and knowledge. I'm loose my mind. All the videos on you tube they seem to come right off.
cknfrmr is offline   Reply With Quote
Old 06-19-2016, 10:09 PM   #2
midniteblues
midniteblues's Avatar
Re: help with front brake drum removel
I've never seen them but I've read on here that the drums were rivited on through the face.
iirc there is 3 find them and drill them.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-19-2016, 10:10 PM   #3
FirstOwner69
FirstOwner69's Avatar
I'm not sure about C10s, but my C20 has the front drums riveted to the hubs. The whole thing has to be removed as an assembly.
FirstOwner69 is offline   Reply With Quote
Old 06-19-2016, 10:15 PM   #4
cknfrmr
I'm going to check the drums for these rivets. Why would GM do this? So people had to go to the dealership? Thanks for this tip. My hammering arm is already feeling better.
Old 06-19-2016, 10:15 PM   #5
GR8-68
GR8-68's Avatar
Hello cknfrmr from your neighbor Mine slid right off after a tap with the hammer but those rivets they are talking about may have already been removed at some point in its life
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-19-2016, 10:32 PM   #6
Mike C
Mike C's Avatar
The OEM drums are riveted. And in order to do brakes with the OEM setup, you have to take the spindle nut loose and remove the hub.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-19-2016, 10:45 PM   #7
saxart
saxart's Avatar
This!!!
Just did the same thing about a month ago. Used PB Blaster, wacked on them with a hammer, then thought, "OK, something is not right here" Researched here and found out the same info. Felt like an idiot!
Once you remove the hub nuts, the entire assembly will come off. After that, you grind off the tops of the rivets and use a hammer and punch to push them through. Didn't need to re-rivet for the reinstall. Not sure why Chevy did it this way.
saxart is offline   Reply With Quote
Old 06-19-2016, 11:28 PM   #8
Gmc.guy
Gmc.guy's Avatar
I have heard they did it so that bearing service/adjustment was done at the same time but I'm not sure
-Cody
Gmc.guy is offline   Reply With Quote
Old 06-19-2016, 11:38 PM   #9
mike16
rear drums on my 27 c10 are riveted
mike16 is offline   Reply With Quote
Old 06-20-2016, 12:06 PM   #10
cknfrmr
I would like to again thank everyone for the help. After taking care of rivets they are off. Ground the flat with the plate they are attached to. Is it fine to leave them that way or do I need to drill the all the way out? They look like above pic. Yall are a awesome group of people.
Old 06-20-2016, 12:14 PM   #11
davepl
davepl's Avatar
My C2500 had a screw on each that serves some purpose for locking the drum to the hub, but I always wondered why since it can't be that strong.
Maybe just prevents them falling off on the line?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-20-2016, 12:32 PM   #12
GRX
GRX's Avatar
I would drill and/or punch them out and be done with them.
It was my understanding these drums were riveted to hold them on through rest of the assembly line since they were installed pretty early in the process.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-20-2016, 01:19 PM   #13
saxart
saxart's Avatar
You could probably leave them that way, but I drove them out with a hammer and punch just because it was a lot easier without the 3 rivets there getting in the way on the re-install. It's hard enough getting the drum back on with 6 wheel studs.
