1964 c10 230 I6 Stumble
Hi,
I need the community's advice regarding the 230 I6 in my 1964 c10. It idles great and runs well with the choke out, but stumbles/bogs and sometimes dies under acceleration at low speeds with the choke in. The firing order, float level, air/fuel mixture, and fuel delivery are all good. Vacuum leaks are nonexistent. I've checked the timing as well, and all seems to well. I'm thinking it might be the jets? Sorry for the long post but I felt I should eliminate redundant replies by listing what I've already checked. What could be the cause of these problems? |
![]() Join Date: Nov 2015
Re: 1964 c10 230 I6 Stumble
What carb are you running?
I had similar issues as you while running the 1bbl Rochester. After switching to a Weber 32/36 life has been SO much better. I haven't had to worry at all.
Post Whore
![]() Join Date: Mar 2013
X2. I went from a rochester one barrel to an edebrock 4 barrel. No stumble now! haha
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Sounds like its better to just ditch the rochester in favor of something better. Thanks for imparting your wisdom to a confused gearhead.
![]() Join Date: Aug 2010
Super common problem. First thing to check for is a healthy stream of gas in the carb throat on acceleration. Get a flashlight, hit the throttle and look for the stream. If you don't see it, accelerator pump is bad or passages are clogged. This would account for falling flat off the line.
Mine would spit back through the oil bath air cleaner and take a few seconds to clear. What I thought was a carb problem healed itself with the junk yard HEI and plug wire installation.
I had previously put in a carb kit. Super cheap at Napa.
#10 | |
Post Whore
FWIW, I just got done installing a pertronix igniter on my 305 V6 GMC. Made a nice little improvement. Idles smoother and pulls smoother. Neat thing is, you can order a pertronix under 292 Inline 6 Chevy and it will bolt right up to a 305E!
#12 | |
Are you sure? What's your initial timing? Is your heat riser working? |
#13 |
Active Member
![]() Join Date: Jul 2007
As mentioned above- check the timing. Easiest thing to check.
Also, make sure you don't have any vacuum leaks. My mono had a gasket leak at the base and also the mid carb gasket was loose. To check this one you have to turn the carb upside down and make sure the two large bolts holding the top and bottom are tight. Check points adjustment and insure the vacuum advance moves freely and is not leaking are things to check. I now have a vacuum pump but you can check the vacuum advance with mouth suction to see if it moves and holds vacuum. One more thing you can dtry is to move the vacuum advance to manifold vacuum at the base of the carb below the butterfly valve to see if it helps.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#14 |
When points go bad you have to "feed your fire" with more choke. A lot of carbs got rebuilt due to bad points. My money is on worn out points and condenser.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#15 |
#16 |
The points and condenser are new, and check out ok on a Sun dwell/tach. The jetting also seems to be proficient. What are probable causes outside the carburetor?
#17 |
Post Whore
You could try more timing, like 8 degrees or even 10.
#18 |
#19 |
I advanced the timing to 10 degrees and that helped the truck run better, but the stumble lives on.
#20 |
*** That's interesting ***
Based on everything else you have done and said, the next thing I'd do is disconnect and plug off the vacuum advance. Take it for a spin. If stumble is still there, the only thing left is the carb.
I still agree with others though, I'm done with points and dwell. I change everything over to electronic ignition of some sort. I even ditch points on old lawnmowers and outboards and swap in Kohler electronic units. Best thing since sliced bread... The new points and condenser kits are junk for just about every application these days. The quality isn't there like it used to be. I learned that lesson the hardest with outboards... try limping back to the launch on one cylinder on a moving river... ![]()
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
