Old 06-21-2016, 12:36 AM   #1
63chevyll
gets board easy.......
63chevyll's Avatar
66 K20 Tow Truck
Hello all
I just picked up this 1966 K20 Wrecker body. Defiantly needs some TLC.
Not sure what to do with it. Its just cool to me. As i sit wondering what to do with it im asking for advise.
Keep it a Wrecker or put a bed back on it. I wasnt sure the desire for factory 4x4s of this vintage. It would need some upgrades for sure.
Cool thing is it has a 396 in it.
Thanks in advance
63chevyll is offline   Reply With Quote
Old 06-21-2016, 01:13 AM   #2
Brad54
Brad54's Avatar
Re: 66 K20 Tow Truck
If it were mine, I'd get rid of the wrecker body and put a bed back on it.
And I'd convert that PTO winch to a front-mounted bumper winch!
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-21-2016, 01:44 AM   #3
jtrichard
BY the badging its a 65
jtrichard is offline   Reply With Quote
Old 06-21-2016, 01:52 AM   #4
62stepside longbox
62stepside longbox's Avatar
Yep I noticed that as well.
Check the vin to know for sure
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-21-2016, 06:05 AM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Is the SPID sheet still on the inside of the glove compartment door?
Could a build sheet still be trapped in the springs of the back of the seat or underneath the seat base?
While it's cool that it has a towing unit on it, it's not a known manufacturer of the day. Putting a box on it as mentioned above would make it a more practical truck.
Did they cut the frame at the back to mount the towing system?
Free wheeling aftermarket hubs a bonus.
Watch your head on the roof mount searchlight. Wack'd mine a few times.
Armored clearance marker lights up front.
1965 GMC Accessories book.
Old 06-21-2016, 10:11 AM   #6
TJ's Chevy
TJ's Chevy's Avatar
I'd leave it a wrecker!!!! Way cooler that way! Everyone has a bed on their trucks! 4x4 ford tower would be sweet!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-21-2016, 10:40 AM   #7
TwoFiftyShifter
It's cool for sure. My father has a '70 K20 wrecker. It was a slide in unit so it still has the fleet side bed, albeit bobbed out back. He scrapped the wrecker unit to be able to use it like a pickup.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 06-21-2016, 12:05 PM   #8
61K10
61K10's Avatar
If it's a org K tk get a bed back on it, unless you want to go into the tow tk business.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-21-2016, 01:43 PM   #9
63chevyll
63chevyll's Avatar
It may be a 65. Ill check the spid. My thoughts too were to put a bed bqck on it and repair the rear of frame
Old 06-21-2016, 02:14 PM   #10
63chevyll
63chevyll's Avatar
Also. Gonna swap in a SM465 with a 205. It has a devorced tase now.
Old 06-21-2016, 10:26 PM   #11
j.kirn
I would be interested in the 221 transfercase if you decide to get rid of it
j.kirn is offline   Reply With Quote
Old 06-22-2016, 01:00 AM   #12
Brad54
Brad54's Avatar
Pardon my ignorance, but didn't they all come with lock-out hubs?
By definition they're free-wheeling, aren't they?
-Brad
Old 06-22-2016, 06:15 AM   #13
aerotruk63
aerotruk63's Avatar
RPO F76 was the optional HUB, LOCKING FRONT WHEEL from the factory.
My 62 did not have free wheeling hubs therefore every time the truck moved the wheels were turning the gears and driveshaft. When you wanted 4WD you wouldn't have to exit the cab to engage your hubs. Puts a drag on the drivetrain when your not free wheeling therefore consuming more fuel.
The factory hub locks were made by DANA and supplied to GM. I just found 3, NOS, in Little Rock Ak. at a truck parts place via the internet using the DANA model part# 22432X last week.
Link to 1966 order form to use zoom:
https://photos.google.com/album/AF1Q...KaEzuKuy4_HigE
GM Factory, DANA supplied HUB LOK's for 1/2 ton.
1963 Chevrolet Truck Silver Book.
These were an aftermarket source for dealerships to install.
Non hub lock 4WD had a simple cover. K25 assembly
Old 06-22-2016, 01:23 PM   #14
61K10
61K10's Avatar
there kinda odd-ball 1/2ton, were only used on closed knuckle 44's. 3/4ton are different.
1961 chevy K10
Old 06-22-2016, 07:27 PM   #15
63chevyll
63chevyll's Avatar
Cant find the SPID. But its is a 65 according to the owners manual and registration.
Also the Proteco plate is in there. Whats the story with that? I tried posting a picture but it won't load
Old 06-22-2016, 08:28 PM   #16
Brad54
Brad54's Avatar
Interesting! I didn't know they were an option... wasn't aware they were available as full-time 4WD.
My '62 K10 has the original locking hubs, and I've got a spare closed-knuckle D44 with what I think are Ford locking hubs.
-Brad
Old 06-22-2016, 08:54 PM   #17
aerotruk63
aerotruk63's Avatar
When the transfercase is in 2H, there's no power from the engine going to the front axle.
Old 06-22-2016, 09:48 PM   #18
63chevyll
63chevyll's Avatar
Cool info
Old 06-23-2016, 06:55 AM   #19
aerotruk63
aerotruk63's Avatar
I have no experience or literature on the Protecto Plate. It should have your VIN number axle codes, etc on it. You would hand it to the service and parts department to help them with your truck. Be interesting to see what info is on it.
Old 06-23-2016, 07:44 AM   #20
60-66
60-66's Avatar
The breakdown for protectoplates is in the front of the parts book
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-24-2016, 01:50 AM   #21
63chevyll
63chevyll's Avatar
Good news. Got the title in hand today. It wasnt an issue as i knew who i was getting it from. Some cool old records from the truck and when it was last in service.
This is realy starting to grow on me. I have a short bed and wanting a long bed. So gonna keep my eyes pealed for a decent enough long bed to throw back on there.
Old 06-24-2016, 02:15 AM   #22
Brad54
Brad54's Avatar
My '76 Powerwagon is set up that way... it was a full-time 4x4 with auto, we swapped in a 205 and stick trans... in 2H, the front axle is still spinning the gears in the T-case, and it's so loud you can't have a conversation.
At some point I'll swap the axles I've got for that truck.
-Brad
Old 06-24-2016, 05:19 AM   #23
aerotruk63
aerotruk63's Avatar
The long bed will make it a more practical truck. What Kind of records did you get?
Old 06-26-2016, 02:05 AM   #24
63chevyll
63chevyll's Avatar
Some parts he bought, the people the previous owner bought it from, what it was used as a Wrecker and what part of the state.
Stuff the replaced on the wrecker bed which indicated the last year it was used
