Conversion u-joints?
I have a 1/2 ton 87 that I put 3/4 ton axles under from a 91 burb. The 3/4 ton axles take a larger u-joint but my 1/2 ton uses a smaller u joint. I talked with a few guys at work and they said spicer makes a conversion u-joint? Any help is much appreciated
![]() Join Date: Mar 2003
Re: Conversion u-joints?
They make them in a lot of sizes,Its best to figure out what two sizes u joints you need and go to any parts store.Theres something that will help http://www.fourwheeler.com/how-to/13.../photo-02.html
user # 2756
![]() Join Date: Jun 2001
Denny's driveshaft has lots of conversion joints. The last conversion joint I used, was the GM3R to 1350, O'riely's had it on the shelf. You will probably need the same, have them cross reference 2-1153.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I bught one for the same scenario from NAPA off the shelf when I put the 14-bolt SF from my '91 V2500 Suburban under my '85 Jimmy. I was going to shorten the Suburban driveshaft once I swapped the 4L80E in, but decided to stay with the 700r4 since it worked fine. The amazing thing is, with a 4" lift I installed at the same time, the Jimmy driveshaft was the perfect length using the 9.5" 14-bolt. Who'da knew? Just too dang easy, these GMs are
Thanks for all the help guys. Im goin to get some measurements this weekend and see if I cant find one!
Try moog 348.
Posted via Mobile Device |
