Tire rub on 5-7 drop
1983 C10. The truck was dropped when I purchased it and needs some serious upgrades ... but ... I was surprised that the only tire rub I have is on the right front when making a medium-to-hard left hand turn.
I assumed that the tires (245/50/20s) were rubbing the fender due to a bad spring cut or some other crazy reason. But I recently put an aftermarket bolt-in battery box in the the truck (the original was about to fall out), moving the battery forward about an inch and up about an inch. Now the rub is much less significant and I am positive that it's the tire hitting the battery box. I can possibly raise the box up another 1/2 inch to 1 inch. Has anyone else experienced this problem? Is it common to have to relocate the battery? I am 98% sure it's a 5/7 drop, but because I didn't do it, it's difficult to tell. There are no inner fenders (not much of anything in there actually). So what kind of trouble will I encounter if I decide to put inner fenders back in the truck. I drive it daily and hate getting the sand/dirt/water off the road in bad weather. Thanks. Robert-- |
Happy to be here
![]() Join Date: Mar 2000
Re: Tire rub on 5-7 drop
With out knowing exactly how you are lowered its hard to target your problem. If your rubbing on the stock battery tray, you will certainly rub on fender liners too. Lets take a look at what you do know, or can figure out and work from there.
Up front look at the spindles and try to determine what brand they are. That will help you narrow down what drop you have. Are the springs stock or after market? What about the shocks? I can tell you that your tire is fairly tall for the drop that you think you have. lets look at what you have before anyone can offer advice on what you should do.
What I do know:
Stock Spindles; Stock Springs that have been cut (not sure how many coils are gone); Stock control arms; BellTech Shocks leaning back and mounted to the frame in an odd location. That's what I do know. Also, the uppers are running up hill from the frame putting, the ball joints in a bind. My plan is to use a 2-inch drop spring, with a 3-inch drop spindle. It wouldn't hurt the truck to come up 1 inch all the way around, but since I've had it I have gotten used to it and I like the stance. (My wife says it's like getting out of the car). I'm gonna need new tires soon (may not make it through summer) so I am gonna have to make a decision soon on the appropriate size because I can't afford to spend money on something twice. |
Happy to be here
If its that low on stock spindles and cut springs, get rid of those springs. I dont care for lowering springs on these trucks. i prefer to cut stock coils correctly (no heat) and cut the correct amount. By 3" spindles and cut a coil off of new springs.
I'm not sure what going on with the shock, but too much angle defeats its ability to perform. Replace the stock mounting studs or splurge on a relocating kit for more travel. Once you get the drop worked out then you can decide what size tires to run.
Part of the prob is the front tire height. 29.5" tall fronts are going to rub something w/a 5" front drop.
