Old 06-21-2016, 08:29 PM   #1
Afirehawk1
66 c10 fender to body bead and inner fender seal
Need some details on how and where to install. Any photos?
Afirehawk1 is offline   Reply With Quote
Old 06-21-2016, 09:40 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: 66 c10 fender to body bead and inner fender seal
here ya go
LT1 Burb is offline   Reply With Quote
Old 06-22-2016, 07:48 AM   #3
Afirehawk1
this is a huge help, thanks!.
now another question. I noticed on the fender is a secondary bracket that i am apparently missing. i have the rear fender seal bracket but not the top one. any suggestions on finding this piece out there.
Old 06-22-2016, 08:45 AM   #4
LT1 Burb
LT1 Burb's Avatar
Ask in the parts section, they are out there.
Old 06-22-2016, 11:29 AM   #5
Afirehawk1
thanks!
Old 06-22-2016, 12:08 PM   #6
LVPhotos
LVPhotos's Avatar
So there is some filler panels at the top as well, left. The ones on right, I believe are the radiator scoop to front panel. By the way, How are you getting staple? Fold over with pliars?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-22-2016, 12:18 PM   #7
Afirehawk1
good pixs. i need the L shaped pair on the top. The longer ones i have. they fit to the rear back section of the fender. the 4 middle brackets you have are interesting. I think i have the 2 straight ones. they fit from the grill support panel to the core support. the 2 on the left i dont have and have no clue what they are? i may need those as well. any sources?
staples? not sure yet but yes most likely using the pliers method with newer staples. havent crossed that bridge yet.
Old 06-22-2016, 03:14 PM   #8
LVPhotos
LVPhotos's Avatar
From the Factory Assembly Manual
Old 06-22-2016, 03:24 PM   #9
Afirehawk1
So that small part is called a filler for the fender.
Thanks for the cut out sheet
I need that part
Old 06-23-2016, 01:56 AM   #10
LT1 Burb
LT1 Burb's Avatar
I bought stainless staples from Ecklers, for corvettes, and folded them with pliers.
Old 06-23-2016, 06:43 AM   #11
Afirehawk1
Good info thanks. I noticed your back side of fender was painted body color. Is that how factory was?
Old 06-23-2016, 09:32 AM   #12
LT1 Burb
LT1 Burb's Avatar
No, they weren't really any color, a mixture of body color, primer and undercoating. I raptor lined everything on the underside and base cleared it.
Old 06-23-2016, 10:19 AM   #13
Afirehawk1
cool. how about the firewall. black or body color.?
Old 06-24-2016, 12:29 AM   #14
LT1 Burb
LT1 Burb's Avatar
Depending on factory built they were fawn or body color.
Old 12-31-2016, 10:08 PM   #15
Afirehawk1
Originally Posted by LT1 Burb View Post
here ya go
Any idea if someone makes the "push pins" that hold these brackets to the fenders?
Old 01-01-2017, 12:28 AM   #16
bill2509
bill2509's Avatar
Classic parts sales them.
bill2509 is offline   Reply With Quote
Old 01-01-2017, 08:36 AM   #17
Afirehawk1
