Old 06-21-2016, 11:38 PM   #1
John in OH
L6 250 Exhaust Manifold to Downpipe Question
I’m currently replacing the intake/exhaust manifold gasket on a 1972 GMC C10 with the 250 L6 engine.
The exhaust manifold to downpipe connection is giving me fits. When I bought the manifold gasket kit it came with a doughnut gasket, but from other postings here, I don’t think my connection requires the doughnut. And after several hours of trying, there is NO WAY this connection can be made to work with a doughnut! My pipe looks kinda like this:
Name:  Walker 48111 Exhaust Pipe End.jpg
The cast face of the exhaust manifold has two studs and an internal chamfer so it “appears” that the downpipe may fit directly into the manifold without the doughnut. There is a clamp flange that slides on the downpipe and pulls the downpipe up against the manifold face via the two studs.
But I can’t believe that this metal-to-metal contact won’t leak! Am I correct? Will it probably leak? The old studs are questionable so I hesitate to torque them too much. Has anyone used a gasket of any kind, or high-temp sealant to assure a leak-free connection?
John in OH is offline   Reply With Quote
Old 06-22-2016, 09:35 AM   #2
Gmc.guy
Gmc.guy's Avatar
Re: L6 250 Exhaust Manifold to Downpipe Question
I am putting my 250 together as well and I have to find a down pipe and flange. So I'm watching this one It might seal Try to get it as square to the opening as you can
With that style flare you might have to trim the end halfway in the "bubble" so that it's a trumpet tip or flare for the donut to fit
-Cody
Gmc.guy is offline   Reply With Quote
Old 06-22-2016, 09:45 AM   #3
Grumpy old man
Grumpy old man's Avatar
While you have it apart remove the old exhaust manifold studs and replace them , if they snap off grind them flat and drill and retap them to install the new studs , oriellys carries the 3 stud package for small blocks and the drills and tap all of it less than $20.00 with new exhaust manifold gaskets , the replacement pipe you have pictured doesn't use a donut but must be torqued up tight to prevent leaks .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-22-2016, 10:20 AM   #4
old Chevy guy
old Chevy guy's Avatar
Like grumpy said. New studs,here's your chance while its apart. That is not the same type of pipe as the origanal. While it's off clean up where it seats with a wire wheel or some sandpaper. New studs and crank her up tight and it should be fine.
old Chevy guy is offline   Reply With Quote
