Old 06-22-2016, 10:00 AM   #1
Kell
Kell's Avatar
Highway gear options/advice?
250 inline 6 with standard 3 OTT. My truck cruises comfortably at 55, anything above that is pushing it in terms of long term reliability I'm afraid. I would like to be able to drive on the highway instead of fearing it, I drive my truck a lot and this would allow me to drive it a whole lot more. I came up with 3 basic options?
1. I have 235/75/15 on there now, I would like to switch to taller tires anyway, but not sure if that will be a noticeable change? Any advice, or pics of taller tires (mine just look too small).
2. Switch the rear end out with an automatic? I've heard the rears are geared a little higher in an auto, this should bump it up some, but possibly make 1rst a little high?
3. Switch the transmission out, this is a pain, and finding a 3 speed with OD would be next to impossible around here. 4 speed floor shift loses some of the old school vibe I like about the truck, but I guess is an option. Have heard certain V6 S10 transmissions will hold up?
Any thoughts? Thanks
1970 C10 Longbed, 250 Inline 6, 3 OTT
Kell is offline   Reply With Quote
Old 06-22-2016, 10:07 AM   #2
benbloom
Re: Highway gear options/advice?
i think ultimately your going to be happiest with an OD trans, with that said changing the rear can make a world of difference on the highway and if you go with something high like a 3.08 you wont need overdrive at all. of course your sacrificing some low end power there, so its all a tradeoff.
benbloom is offline   Reply With Quote
Old 06-22-2016, 10:13 AM   #3
barry1982
Hi There,
If I was doing it, think I would try find a Diff from a 67-72 that had a 350/Auto. Pretty sure those had a little higher gear ratio than your 250/3 speed. In the late 70's early eighties GM offered a 3 speed standard with overdrive. I believe it was called an "A833" . They are rare..... (I have a couple). Both of mine came in 1982 GMC 1/2 tons with the 6.2 liter Diesel. These transmissions can be bolted to a Chevy V-8 or 6 cyl. They came factory with a "Hurst" type floor shifter.
barry1982 is offline   Reply With Quote
Old 06-22-2016, 10:15 AM   #4
Mike C
Mike C's Avatar
One nice thing about the 6 cylinder is that the 4.3 V6 T5 is a great transmission to swap in and they aren't real expensive compared to the harder to find more expensive V8 transmission. That would be my first choice for better all-around drive ability.
The other choice is to your point, taller tires. Or switching to lower numeric gears (you should have 3.73 so 3.07 would lower rpm 20%) but these also all reduce the low speed gear reproduction.
More difficult is the T5 swap, but more value to be had as well IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
