PITbut
Hopefully a simple question. Blazer frame.
The rear end of my blazer has taken a beating. The PO had a hitch welded in, a bumper welded in and its just beat up back there. I want to replace the back 12 inches or so. Do they sell c channel roughly that size that i could cut the old out and weld in some new metal? Im not having any luck finding a frame i can use as a donor.
Thanks guy.s
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
![]() Join Date: Jun 2014
Re: Hopefully a simple question. Blazer frame.
Call up Frank at pickmups in Olympia. he can probably help you out. 360-956-7170
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
PITbut
Left him a message.
![]() Join Date: May 2011
4x4 or 2wd and what year I might be able to help.
PITbut
I have some frame channel from a 72 I cut up if you measure the channel width I can check and see if it is the same.
PITbut
I will measure the inside width and get back to you today.... Thanks for the help.
The rear 72 frame rails extend all the way out to the bumper and require different bumper brackets, and gravel shields than a 71. Also, your 71 will not have the cutouts along the rear lower panel of the body to clear the frame rails. Just some things to consider if you go with 72 rear rails instead of 71 rails.
#9 | |
![]() Join Date: Nov 2015
Ive got a rolling bare blazer frame Im selling for $200 if youre interested. Not sure if you already fixed yours.
425-231-8780 Don |
#11 | |
PITbut
4wd frame im assuming... I really just need the back section of the frame. When can i come take a peak at it? This weekend i have a wedding, but im free next.
#12 | |
PITbut
Thanks Don.
