New parts, now won't start
I swapped a busted Edelbrock for a new Holley 650 DP, and a locked out GM HEI for a new MSD street Fire HEI, and a crappy alt for a new Powermaster 105 alt, and now it won't start. It tried a couple times but that's all I could get it to do.
Any ideas? I dropped the distributor in exactly how it came out. And it's getting fuel because the carb squirts... |
Re: New parts, now won't start
Overview if this helps
Anybody have any ideas? It ran before even with the cracked carb and the weak alternator. I'm totally stumped and want to drive this thing
Did you check for spark? When it tried to start was there any backfiring?
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
New alternator hooked up right? Sounds electrical to me.
I didn't check for spark because it tried a couple times but I'll make sure right now.
If you have fuel and spark it should run. Are you sure the dizzy is clocked properly? It will act like this if the timing is off.
I thought it could be 180* out but I'm positive I put the new one in just like the old one came out. I guess I'll have to pull it and try the TDC #1 process
![]() Join Date: Dec 2013
Always Mark the rotor position when lifting the dist it will clock the oil pump forward making the timing advanced when dropping the new one back in .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
When I pulled the old one out it was pointing at #6 so I figured just position the new one the same way. I must have put it back in wrong. Another thing I did was take the distributor cap off and removed the actual rotor when I put new weights and springs in. Can the rotor be re installed pointing either way or is there only one way to screw it back on?
#13 |
I turned the motor over til it was at #6 TDC and dropped the distributor in with the rotor pointing at #6 and no change, still won't start. I'm stumped on this one. The carb squirts and I pulled a plug and it's sparking like crazy
#14 |
Ok, so I took the valve cover off and started at square one to totally rule out the distributor being a problem. Turned the motor over to #1 TDC, bothe valves closed, and pointed the rotor towards #1. Still nothing
There's a metal flap where the choke it on the carb, is that supposed to open when the throttle is opened? |
#15 |
Ok it fired up and I kept it running, but I had to crank the distributor WAY over counter clockwise. See the picture and then let me know what you think
#16 |
![]() Join Date: Feb 2013
I would slow down, sounds like you have insured that it is not electrical, also sounds like you are sure its not fuel because you have fuel in the carb.
I say it has to be timing still. Take you time, check the firing order a couple times, its easy to cross wires and otherwise get things wrong. At this point I would roll the engine over to TDC and stab the dizzy back in and see what you get. If nothing, over again and stab it back in. If all else fails start rotating the wires around the dizzy till she hits. |
#17 | |
I pulled the distributor and checked everything and it did fire, but only after I turned the distributor way to far over counter clockwise. The vac canister is almost pointing forward |
#18 |
![]() Join Date: Mar 2003
It's off 1 tooth.
#19 |
#20 |
![]() Join Date: Jun 2009
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#21 | |
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 06-22-2016 at 11:05 PM. |
#22 |
Yes. Turn the oil pump shaft till the rotor moves back enough. You might half to take it in and out a couple times till you get it right. Also you can move all the plug wires over one spot.
67 short bed step side build |
#23 |
Don't move the wires , fix the problem .
#24 | |
Good grief I know you're trying to help but sometimes you don't give me any credit for having listened and learned a little. I'm not just takin shots in the dark here, I've done a lot of research and reading and figured out exactly what I need and what will work best. Almost everything I read is David Vizard and I think you'll agree he's pretty awesome. The new distributor comes from the factory with very very heavy springs in it. The specs are 24 degrees all in at 4000rpm. That's too much timing and way to late for my combo to work the way it's designed to and run efficiently. The springs and weights I put in limit the mechanical timing to 22 degrees, and it's all in at 3000 rpm. This is very conservative relatively speaking, and will run 10x's better than it did out of the box. I bought this specific MSD distributor so that I could make my own timing curve because with my combo of heads cam intake and carb, the factory setting won't work. No starter button YET, I didn't turn the motor over while doing the distributor change, and I took pictures of the rotor so I could put it back right and was only one tooth off. Just help out in my threads instead of jumping in to EVERY single one I post and bashing me. |
#25 |
![]() Join Date: Jul 2015
