Old 06-23-2016, 07:04 AM   #1
[JP]
[JP]'s Avatar
Suspension options help please
Hello everyone…
Need some help here if you were so kind to share your knowledge and experience on this.
After much work since my truck got to the UK I have been happily enjoying driving it…. But….. suspension!
Its really bothering me and would like to know what would you experienced people would do.
Facts:
I love the stance.
The height, front and back is spot on, just as I want.
Would like to keep it just as is.
What have they done:
Cut the front springs too much – it’s so cut that they have chopped the rubber stop bracket and put a chain link to stop the spring from popping out.
Rear – seems ok, looks like drop springs in the back.
Problem:
When going over potholes on the road, like small holes where your tyre just fits (not sure if in the US you use the term potholes), the sound of metal banging together is making my heart bleed. (I need to put my gopro underneath and drive around to check what exactly is happening)
When going over slight depressions and bumps, say like a roller coaster, it feels like it bottoms out on the shocks. I don’t get the harsh metal bang but get the bottoming out sound.
What I would like:
To keep the ride height I have now but stop the harsh banging of metal.
Dont need to have air ride to drop it all the way to the floor but thought air ride could be a way of stopping the banging and at the same time keep the truck at the height I like?
What are my option here? What do you guys think is happening?
If I was to get new shocks, maybe heavy-duty shocks would it stop it from going down to harsh?
I don’t want to go down the drop spindles route as then I have to add disc brakes etc etc….
Or should I go down the air ride route? If so.. what exactly do I need?
I have seen the kits, seems pretty easy but if adding air ride, then what about track control arm, like the rear one? Doesn’t it need to change as the ride height goes up and down? Do I need one of those 4 link arms?
Thanks!
My 65 stepside build/work on thread - http://67-72chevytrucks.com/vboard/s...d.php?t=693138
[JP] is offline   Reply With Quote
Old 06-23-2016, 10:46 AM   #2
duallyjams
duallyjams's Avatar
Re: Suspension options help please
I would upgrade to drop spindles ( disc brakes ) porter built upper and lower control arms ( will center the front wheel ) and a drop coil spring, it will ride better, steer better and stop better, it would be a win win win
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 06-23-2016, 11:09 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
It's all about wheel travel. With that setup you have very minimal travel (look at the lower are to the spring pocket lip). Might be fine on a perfectly smooth road but you will never prevent it from bottoming out. Normally that space is 4-5" apart and you're close to less than 2". Airbag or stiffer shocks are not going to solve this problem. Dropped spindles and taller springs (to get a net height the same) will allow more wheel travel and help prevent bottoming out.
I had a similar issue on my '65 C10 when the person before me used 3" dropped springs. It would bottom out all the time. I replaced with 2" dropped spindles and 1' dropped springs (same 3" total drop) and it rode SO much better. It almost never bottomed out.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-23-2016, 11:38 AM   #4
[JP]
[JP]'s Avatar
Thing is for you guys is all cheap (or cheaper than here), I was trying to avoid going the drop spindles route because then it means getting disc brakes, calipers, master cylinder, then I guess the hubs would be 5 stud? get rims for it... etc,etc... its a whole load of things, its a never ending story of parts right?
Say if I was to install air ride... I could lift it on the roads I know are not very good and then drop it down for town driving?
How about that? would that work?
Old 06-23-2016, 12:50 PM   #5
tinydb84
tinydb84's Avatar
They make conversion kits to keep the same rims. The brake upgrade is well worth it in my opinion.
You can definitely install air ride. Just air up when driving and air out when parking. For the cost of the bags, line, valves, compressors, tank, wiring, etc will likely cost just as much as the spindles and brakes.
David
Instagram: myfabguy
Old 06-23-2016, 12:56 PM   #6
[JP]
[JP]'s Avatar
Hmm ok Yes I see what you getting at.
Cost wise being the same then I'd have the added bonus of better brakes....
Is there a company that would do the whole thing?anything people usually go for?
Or just LMC catalogue and get all the separate parts off there?
Old 06-23-2016, 01:02 PM   #7
tinydb84
tinydb84's Avatar
The nice thing about going with the new brakes and drop spindles is that you are going to want them when/if you bag it later.
Here is a full kit that includes everything: http://www.azproperformance.com/Pro1...60-72-C10.html
David
Instagram: myfabguy
Old 06-23-2016, 01:25 PM   #8
[JP]
[JP]'s Avatar
Thanks!!!that looks the nuts!and cheaper than the air ride kit...
Sounds like a good option. Could go with the 2.5" drop spindle and a 2"drop coil I guess?
Also like the fact it can be selected as 6 lug pattern.
Ohhh what about overall size?would the disc and caliper fit inside my 15" rim?
Old 06-23-2016, 02:34 PM   #9
tinydb84
tinydb84's Avatar
The stock disc size isn't usually an issue. The issue usually comes up with a 3 inch drop spindle. I know there are a number of threads discussing the rim size and drop spindles.
David
Instagram: myfabguy
Old 06-23-2016, 05:58 PM   #10
[JP]
[JP]'s Avatar
Hi, just another question, would these be any good?
https://www.summitracing.com/int/par...del/c10-pickup
Because I think it's easier for me to get stuff from Summit Racing than that company you posted (someone here in the UK who deals with summit)
thanks!
Old 06-23-2016, 06:06 PM   #11
68racer
Yeah baby!
68racer's Avatar
Hi, I have some after market shocks, drop spindles and a disc/drum master cylinder. PM for details. Also its cheaper to ship direct from Summit. Neil.
11.37 @116
68racer is offline   Reply With Quote
Old 06-24-2016, 01:00 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
thanks!
You can send us an email and we can help make some recommendations.... We understand if it's easier to purchase through Summit, but we don't mind helping you acquire a parts list.
sales@pbfab.com
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-01-2016, 08:32 AM   #13
[JP]
[JP]'s Avatar
sales@pbfab.com
Nate
Hi Nate,
sorry for late reply, only seen this now!
I will send an email see what you can get..
not the best time of year now for me to be buying, since England voted out the EU, the exchange rate turned to crap... but I still want to sort this ride out!
thanks
