Front brake hoses
can someone please tell me what front brake hoses they have used on a 71 stepside front, with dropped spindles. Only i have several sets which do not reach, especialy after searching on here.if you can tell me which application they are for , i can order a set
best wishes adrian.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
#2 | ||
"I ain't nobody, dork."
Re: Front brake hoses
I am sure you can get longer lines that will fit your truck from places like Inline Tube or any other brake and fuel line company.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Hi Gary
i you note i am from the united kingdom , so its earier to get a hose from a production vehicle if possible.
![]() Join Date: Feb 2016
71-72 one ton dually hoses. They are longer but otherwise the same as half ton hoses. That's what I've used on a couple of trucks that I lowered.
#5 | |||
Gary
Old member
I ordered my S/S front lines from here on E bay. He will make them any length you want them also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
