Old 06-23-2016, 07:51 PM   #1
bvb69C10
Rear window seal
I recently purchased a rear window seal for my 1972 c10 from Steele Rubber. I also bought new glass from a local auto glass company. The company I bought the glass from installed the window yesterday using the string trick to install it and the seal looks like crap on the outside of the window. It sticks out at the bottom about a 1/4 inch from the cab in one corner and isn't really completely flush to the cab at all in most areas. So does any one have any experience with Steele rubber? Should I try a different seal? Any suggestions of which seal from anyone who's had success? The old seal which was probably OEM fit great. It's a leak waiting to happen at this point. Any help would be appreciated.
bvb69C10 is offline   Reply With Quote
Old 06-24-2016, 08:56 AM   #2
Jason Banks
Jason Banks's Avatar
Re: Rear window seal
I think this consensus here for windshields is Precision brand. If i were buying a rear window seal. I would hit up one of the board vendors like GMC Pauls and get their advice. I'm pretty sure they wouldn't lead you wrong.
Jason Banks is offline   Reply With Quote
Old 06-24-2016, 09:02 AM   #3
Grumpy old man
Grumpy old man's Avatar
Sounds like an installation issue , Whats it look like on the inside ? Steele rubber has been around forever and make some of the best products out there , the "string trick" should actually be done using 3/16 cord to pull the inner lip all the way in .
Post a few pictures .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-24-2016, 10:36 AM   #4
Andy4639
Old member
Andy4639's Avatar
Unhappy Re: Rear window seal
This is my opinion and mine only.
I grew up down the road from Steel rubber and I wouldn't use nothing they sale. This is my personal opinion only. I have tried their stuff several times and had to replace it every time.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-24-2016, 08:23 PM   #5
bvb69C10
Well call me stupid! The errors on me. I should have looked at the trim before buying the seal. Apparently the previous owner put 67-70 style seals on a 72 cab. The trim tab that pushes into the rubber on the earlier years is centered and 5/8" long. The trim tab on 71-72 models is offset and 1/8" long. I put the long tab in the shallow seal....no wonder the trim doesn't fit and the seal won't lay flush on the cab. Another lesson learned on my journey to rebuild an old Chevy truck. Thanks to all for your words of wisdom.
