06-24-2016, 02:25 AM | #1 |
70 4speed clutch to newer block?
I need to replace the engine in my 70 c20. I was thinking of getting a reman or new vortec motor and installing a carb on it. I know I need a new flywheel and harmonic balancer for the 1 piece rear main crank. Will the clutch bolt up to that flywheel? What clutch do I order? I think I have the SM465.
Thanks! |
06-24-2016, 09:03 AM | #2 |
Re: 70 4speed clutch to newer block?
The clutch should bolt up. Just make sure you get a one piece rear main seal flywheel that is drilled for the 12" clutch which should be what was in front of the SM465. Just order a replacement clutch for your year truck.
06-25-2016, 01:25 AM | #3 |
Awesome thanks! I was hoping the pressure plate would bolt up. Do I need a special Pilot as well?
06-26-2016, 07:56 PM | #4 |
I don't think GM made any changes to the pilot bushing, but you will find that out!
