06-24-2016, 09:22 AM | #1 |
Blue 67
Starter issue
Hi:
Lately when the engine is warm, it can be just 5-10 minutes, if I turn the engine off I can't start it again. The starter make this loud grinding noise but it doesn't feel like it is engaging the flywheel. I have to let sit until is completely cooled down until I can start the engine again.Any ideas? Is the starter on its way out? I don't have any heat shield. The engine has the stock manifolds ((no headers). Besides, I thought heat soak cause the starter (the solenoid) not to anything rather than making grinding noises when it is hot. Thanks,
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
06-24-2016, 01:03 PM | #2 |
Re: Starter issue
Heat soak causes starters to require more power to engage. When that power exceeds the purple wire's ability to carry it, people call that heat soak. When the purple wire has been compromised, people bandaid it with Ford solenoids and stuff. It's a hobby of mine, but not what you're running into.
Sounds like you're right on the edge of proper clearance and then once things get warm and expand, you're too far out. Here's a video, or you can google "shimming a gm starter" https://www.youtube.com/watch?v=3cYqrKmVECY
