Old 06-24-2016, 09:26 PM   #1
Mjminino
Turn Signal Switch
Would this work for C10's? It says it is "A NOS 1966 CHEVY TRUCK TURN SIGNAL SWITCH FOR THE 4000 - 8000 MODELS" I'm assuming that that means C40-C80? It looks like it would work, just with metal pieces. As far as I knew, outside of maybe the COE's, the columns were all the same???
Mjminino is offline   Reply With Quote
Old 06-25-2016, 12:46 AM   #2
jtrichard
Re: Turn Signal Switch
What I found is its for a TILT cab So i would say the column is different
jtrichard is offline   Reply With Quote
Old 06-25-2016, 07:35 AM   #3
Mjminino
What's the difference between tilt and non tilt wiring
Old 07-13-2016, 08:41 AM   #4
Mjminino
It didn't end up working. The holes did not line up. Someone told me that they didn't offer tilt columns in these years.
Old 07-13-2016, 10:27 AM   #5
jtrichard
NO TILT COLUMNS is correct it is for a tilt CAB (COE) truck with a column that is different than what is in a C 10/20/30...... Also 4000/8000 would be GMC designation and the (C) in C10.20 ECT. is for CONVENTIONAL cab
