Old 06-24-2016, 10:12 PM   #1
AASmedic
AASmedic's Avatar
Windshield gasket debate/problem
As most of you can probably relate, it is a pain to get a new windshield gasket that fits correctly. I have read many post and threads that speak of the night mares that people have endured to replace a windshield and gasket. Heres my problem.....
I have a 72 K20. My truck has the "shallow" stainless trim around the windshield. I purchased a new gasket and tried to install everything and failed at least 5 times. Upon further investigation I thought I may have the wrong gasket. I went to my local "parts guy" and he said, yes I have the one for the "shallow" trim used on the 71-71 models. I got it home, opened the package and low and behold........its the same as the one I had. It is the Counterpart Automotive gasket. Does anyone know if these are made universally to accept either the shallow or deep trim?
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 06-24-2016, 10:22 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Windshield gasket debate/problem
No 2 different gaskets for 2 different trim styles the early set works best
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-24-2016, 10:45 PM   #3
AASmedic
AASmedic's Avatar
So the gasket that accepts the deeper trim works best for the shallow trim as well?
Old 06-25-2016, 09:27 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Are you using new or OEM trim? New trim won't work. I can recommend two local auto glass guys who are experienced with installing the trim/glass if that helps. I've had good luck with Precision brand gaskets.
Old 06-25-2016, 11:28 AM   #5
frenchy51
frenchy51's Avatar
Call "Precision" They are knowledgeable and have the BEST gaskets. I know from experience.
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 06-25-2016, 11:55 AM   #6
AASmedic
AASmedic's Avatar
I have OEM trim.
Old 06-25-2016, 12:02 PM   #7
AASmedic
AASmedic's Avatar
I would definately be interested to find someone who is experienced at this.
Old 06-25-2016, 12:12 PM   #8
frenchy51
frenchy51's Avatar
I had the same problems as you. The "precision" gasket was used with my original chrome trim and it was installed by my local glass guy. I watched him-he had no problems with the precision gasket-unlike one I got from Brothers....just telling you my experience.
1977 GMC HeavyHalf
Old 06-25-2016, 12:16 PM   #9
davepl
davepl's Avatar
Having just done this I can saw that the reproduction chrome trim doesn't fit well. The 'L' part that comes in and hooks the rubber isn't deep enough to actually grab the channel that its supposed to. The factory stuff is much better.
That said, it CAN be made to work, but its not ideal.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-25-2016, 12:16 PM   #10
AASmedic
AASmedic's Avatar
Thanks. I appreciate it. Time to call precision
Old 06-25-2016, 01:17 PM   #11
davepl
davepl's Avatar
It'll work, it's just not as easy. The window I took out was beautifully installed with repop trim, so it be done. Given the choice however the OEM trim fits much better.
Old 06-25-2016, 02:36 PM   #12
AASmedic
AASmedic's Avatar
I guess I should probably say that I assume its the OEM trim. Any way to tell for sure?
Old 06-25-2016, 03:07 PM   #13
davepl
davepl's Avatar
My OEM stuff had broach marks near the bends, the repro does not.
The OEM stuff is deep enough to "hook" the inside lip in the seal, but the repro is just a little too short.
Old 06-25-2016, 03:16 PM   #14
AASmedic
AASmedic's Avatar
I guess I am not familiar with broach marks. I do know that the 2 seals that I have purchased are exactly the same and appear to have 2 lips in the trim channel. An upper one for the shallow trim and a lower one for the deeper trim. One of the seals was supposedly for 71-72 trucks with shallow trim. I purchased a second seal thinking I had the wrong one but they are exactly the same
Old 07-05-2016, 07:40 PM   #15
AASmedic
AASmedic's Avatar
Well I have to give a big THANKS to Dustin at Metro Auto glass and for those of you who recommended that I use the Precision windshield gasket. The install was a breeze and the fit and look are awesome. Thanks to DeadheadNM for the recommendation of Metro Auto Glass.
