![]() Join Date: Feb 2009
WTB - 1971 C-10 OEM parts
Good steel, no dents stripped parts or pitting please...Thank you.
1. One NOS hood spring. 2. NOS LH hood hinge, depends on rivet type. 3. Mint LH exterior door handle. 4. Two park light housings with the cable & rubber like new. 5. Mint NOS non-tilt shift lever. I believe the part # is 3990301. 6. Hardware for the ground strap from bed to frame. I don't know what the correct hardware is (mine was missing). 7. Four 1/2" head tapered screws (i.e. bolts) with integrated washers to mount the cowl panel. Really, they're body bolts with a 3/8" x 7/8" thread. That said, 3/8" x 3/4" works too. 8. Anti-Dieseling Relay hardware. Again, I don't know what the correct hardware is (mine was missing). 9. Blower Vent Tube for A/C. If by chance it's super then I'll take it. 10. Interested in the small parts (retainers, screws, nuts, clips etc.) for an A/C system, from the evaporator box forward. Some of those retainers are nylon. Would prefer the nylon is nice, but it doesn't have to be. 11. Center A/C vent housing (aka assembly), good condition and good teeth. I could use a nut or two for attaching the vent to it as well. These have a washer set into the nut. I wouldn't mind a center vent either, if the chrome is nice and the price reasonable. 12. Window regulator screws. These are phillips head screws with integrated star washers. The threads are 1/4" x 1/2". I only need one, but all eight works too. 13. Edit: Add LH NOS door latch control.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-25-2016 at 12:16 PM. |
![]() Join Date: Dec 2013
Re: WTB - 1971 C-10 OEM parts
Call Dean Johnson at
the Chevy truck farm 4129 Russel Dr Kodak , Tn 37764 865-654-2992 Dean has about 70 trucks and has buildings full of parts , he sells on eBay but the best stuff is in his buildings , he usually has some or the rarer trucks and parts . He's only 20 minutes down the road if you need something eyeballed or possibly help shipping .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#3 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
